Control Arm Bushing Advice Needed
Old Mar 10, 2022 | 12:47 PM
surfin_phil's Avatar
surfin_phil
6th Gear
Default Control Arm Bushing Advice Needed
Hi
I have a 1992 C4 Base. Have the heads off etc so I have space to do some other work while I'm at it.
I'm replacing the steering rack, ball joints and tie rod ends.
Noticed the rubber control arm bushings looking pretty cracked and dried out so I want to replace them.
I've used polyurethane in other vehicles and wasn't impressed as they squeak a lot and eventually dry out and fail.
Any suggestions/advice on anyone selling refurbed control arms or good experiences with a particular brand of bushings etc would be much appreciated.
Phil.
Old Mar 10, 2022 | 10:35 PM
wikdwizard's Avatar
wikdwizard
Check out what Global West has to offer.
Old Mar 10, 2022 | 10:56 PM
84 4+3's Avatar
84 4+3
Global west is great. You can also use the super pro setup depending what you want from the car.
Old Mar 15, 2022 | 02:18 PM
MatthewMiller's Avatar
MatthewMiller
Up front, using poly is fine. I actually had them and never had a squeak. I would guess that SuperPro is both longer-lasting and easier to install. The Del-A-Lum bushings are great, but probably a little overkill for an otherwise-stock street car. There are no rubber bushings or refurbished arms with new rubber bushings available anymore.
Old Mar 15, 2022 | 03:40 PM
surfin_phil
6th Gear
Thanks Matthew.
I ordered a set of Del-A-Lum bushings.
Are there any down side to these, like harsher ride, too much road "feel" etc?
Old Mar 15, 2022 | 07:02 PM
MatthewMiller
Originally Posted by surfin_phil
Thanks Matthew.
Those things are the shizzle. They might ride slightly harsher, but there won't be too much of a penalty. In a C4, the lower control arms take only small vertical forces from bumps because the springs are fairly far outboard on them, and the uppers take none at all. I think you'll be happy with them. Let us know what you think after you're done with the installation.
To Control Arm Bushing Advice Needed
