C4 Starting Issue
Old Mar 24, 2022 | 06:28 PM
RaceMic's Avatar
RaceMic
Default C4 Starting Issue
I have a 1996 LT1 and have had not a single mechanical issue for over 10 years. Recently, the starting became intermittent. Now when I turn the key, the dash lights illuminate, I hear a loud click, and the car goes completely dead as if there is no battery. I can start this process over by disconnecting and reconnecting the battery. I considered it might be a VATS issue, but because the starter relay is clicking, I'm not so sure. What is perplexing is that the car goes stone cold dead right after the "click".
Does this sound familiar to anyone? Any ideas?
Old Mar 24, 2022 | 06:31 PM
WVZR-1's Avatar
WVZR-1
With Key ON not 'cranking' Is the 'SECURITY' light lit? If yes then likely VATS but .......
How many miles? Has it ever to your knowledge had a starter replaced?
Sounds typical of a 'higher mile' C4 with a 'denso starter. There's several threads regarding that starter and what it likely needs. DO NOT buy a starter motor. No guarantee that the contacts, plunger and related parts will fix but it costs very little. If you do your own repairs - parts should e local.
Old Mar 24, 2022 | 06:48 PM
s carter's Avatar
s carter
It sounds like poor power connections to me, how old is the Battery and is there corrosion on the terminals. My car has done this same think Click Dead grab the Battery connection give a tug and it would start.
. So load test battery and clean connections make sure there tight not just snug work from there
Old Mar 24, 2022 | 06:49 PM
RaceMic's Avatar
RaceMic
48.5K miles. No, the security light does not illuminate. Why would a bad starter cause the entire car to go dead?
Old Mar 24, 2022 | 07:12 PM
RaceMic's Avatar
RaceMic
A lesson from the "always check the basics" school:
This issue started right after I changed the battery a couple months ago. Sure enough the quick disconnect had worked (very slightly) loose. DOH!!!
Starts like a brand new car now. Thank you for resetting my brain.
Old Mar 24, 2022 | 11:08 PM
pedricd's Avatar
pedricd
Glad you got it figured out. EXACT same thing happened to me due to not tight enough batt terminal. Car powered up, go to crank and the entire car goes dead. Had a new battery popped hood wiggled battery cable and retightened and it was fine.
Yours was a quick disconnect but I think the battery terminal style is prone to this happening (I had to make mine a lot tighter than I thought). I’ve read a few others her post the exact same thing!
Old Mar 29, 2022 | 08:56 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I was just about ready to tell you to test the battery and its connections. But I see you've solved the problem. You da man!
To C4 Starting Issue
