Copper antiseize compound vs. silver
Old Dec 30, 2002 | 11:38 PM
Lone Ranger's Avatar
Lone Ranger
Default Copper antiseize compound vs. silver
Stumbled onto info in another thread that it may be bad idea to use a copper based anti-seize compound for spark plugs in an *aluminum* head, and should use one of the silver colored compounds instead? How come? I thought copper was a better conductor for enhancing the ground connection from head-to-plug?
:chevy
Old Dec 30, 2002 | 11:39 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Copper antiseize compound vs. silver (Lone Ranger)
>shrug<
I go all the way and use the nickel-based nuclear grade anti-seize we use at work. :)
Old Dec 31, 2002 | 07:22 PM
Lone Ranger
Default Re: Copper antiseize compound vs. silver (Matt Black)
>shrug<
...nuclear grade anti-seize we use at work. :)
:eek: Dayum!
Old Dec 31, 2002 | 07:36 PM
CowboyNVette's Avatar
CowboyNVette
Maybe its because some metals just don't go good together. With the right combination of metals you actually create a battery like situation, where one is cathodic to the other. I know if you put two metals side by side in a solution you can make battery, depending on how dissimular the metals are...Damn that is how batterys are actually made :lol: But seriously if you have the right combination of metals together one will draw current from the other and the one that the current leaves deteriorates.
Not sure if that is the reason but could be. BTW Copper anti seize is for higher temperatures than the silver. Much higher than your engine should be. :smash:
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Use the Silver! (aluminum)
Copper and aluminum don't get along! Aluminum will breakdown in the presence of copper and moisture (electrolysis)
May take a long time for it to happen, but play it safe
:seeya
Old Dec 31, 2002 | 08:44 PM
1MoorTym's Avatar
1MoorTym
Default Re: Copper antiseize compound vs. silver (jackdaroofer)
Check this out
http://www.permatex.com/products/pro...&item_no=09126
Use this on all my plugs.
[Modified by 1MoorTym, 8:45 PM 12/31/2002]
Old Dec 31, 2002 | 09:15 PM
Corvette0096's Avatar
Corvette0096
:seeya
:iagree:
Old Dec 31, 2002 | 09:47 PM
hngacurv's Avatar
hngacurv
Default Re: Copper antiseize compound vs. silver (corvette0096)
Whoa, that was close. I just bought my NGKs today and going to try and put them in tomorrow. The anti-seize I bought said for aluminum heads, but it's copper based. Think I'll go trade it tomorrow for silver.
Old Dec 31, 2002 | 11:33 PM
merrick's Avatar
merrick
Default Re: Copper antiseize compound vs. silver (castivers)
Copper is fine. Good enough for aircraft engines, even have a copper gasket to match. You might not want to use it on your A-bomb :lol:
Old Jan 1, 2003 | 12:48 AM
h rocks's Avatar
h rocks
Got one can left of the original Anti-Seize. You know, the one you can't buy any more with the carcinogenic carrier and nickel. Great stuff. A little tiny bit goes a long way.
Old Jan 1, 2003 | 05:27 PM
no_radio's Avatar
no_radio
Default Re: Copper antiseize compound vs. silver (h rocks)
The silver is actually nickel based, not aluminum based.
We have experienced SERIOUS corrosion problems in offshore and deepwater oilfield applications when using copper based anti-sieze with stainless steel fasteners. We don't use aluminum (corrodes WAY too quickly) so I can't speak to the compatibility there, but if you are using stainless steel fasteners, like ARP stuff that I use, I would strongly recommend using silver anti-sieze. You may not have the catastrophic failures we've seen, but it can't be good in any conditions to have the copper stuff on stainless.
Jeff
Old Jan 1, 2003 | 06:07 PM
1MoorTym's Avatar
1MoorTym
Default Re: Copper antiseize compound vs. silver (no_radio)
Be careful here with just using color to indicate composition. The permatex site lists the silver as having a combination of both aluminum and copper materials. Only the Nickel anit-seize label as "Nickel" contains no aluminum.
Old Jan 1, 2003 | 09:13 PM
Wadoka's Avatar
Wadoka
Default Re: Copper antiseize compound vs. silver (1MoorTym)
Our nuke grade AS is nickel based, and what makes it nuke grade is that the carrier is certified as low chloride/low halide, less than 250ppm total halides.
That just means that it doesn't facilitate chloride-aggravated stress cracking in stainless steels at high temps and pressures.
To Copper antiseize compound vs. silver
