1994 Check gauges
I looked in the forum if there was a topic already open but I didn't find it, if it already exists sorry.
I have a question for you.
My Vette is a 1994 with automatic transmission, and the "check gauges" light comes on or blinks for some time.
With the machine running cold for a few minutes it does not turn on, then it starts instead.
Sometimes accelerating it turns off for a few moments or fades in intensity.
Any ideas or suggestions on where to look?
For '93 and newer it's always been available from GM in .pdf for FREE. Today that link isn't populating. It is for years newer so maybe that's a recent change to exclude a few years. Don't know.
If it works later I'll post it. It seems that all C4's have 'maybe' been eliminated from the FREE 'OWNERS MANUAL" access. First year that populated was '97 (C5)
I replaced the float and fuel pump, I have no problems with temperatures and volts. I think it may depend on an old sensor that gives some wrong signal, but I don't know where to start looking ...
I will end up switching off the light ...
You would need some diagnostic information and be familiar with the procedure. I have the 8D section of a similar year ( '96) diagnostics in a file that's small enough that it might email. PM me an email address and I'll try sending it.
There's also information here but I'd think the 8D section of the FSM would likely do better.
https://tech.corvettecentral.com/201...trouble-codes/
From an Owners Manual
'93 - '96 Owners Manuals seem to be available FREE from Corvsport still.
https://www.corvsport.com/free-corvette-owners-manuals/
The only "strange" thing is that I have a current leak, possibly caused by the car stereo. If I leave the battery attached, and don't use the car for more than two days, the battery will run out.
But he's been doing it for a long time and I didn't have this problem.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAA AAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMS tlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyYYD7fkr6l 4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOV KSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9tw Z+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZ Rx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY 51A+hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyW TOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
I noticed something, and I wanted to know your opinion.
If I look at the oil temperature on the display I see that it indicates 103 °C, but the pointer on the dashboard does not go up, or it goes up very little.
Do you think it could be the cause of the light on?
When in doubt I order it to change it and we hope so.
