Idle issues ?
Old Apr 11, 2022 | 07:25 PM
Charles212's Avatar
Charles212
Default Idle issues ?
1985 C4 question:
Is there a reason why the idle, better while in park, is not as smooth when I come to a stop sign/light? I have installed a new IAC and TPS.
Charles
Old Apr 11, 2022 | 07:39 PM
CorvetteRules's Avatar
CorvetteRules
Because of the load on the motor when sitting in gear while at a light?
Old Apr 11, 2022 | 07:41 PM
Charles212's Avatar
Charles212
So, should the idle and timing be set for the car in park or the car in gear?
C
Old Apr 12, 2022 | 09:25 PM
krackenvette's Avatar
krackenvette
I am pretty sure your car is timed, with engine at temp and at 6-8 BTDC, vacuum line from distributor unplugged? Been a long time since setting timing on these engines..
Old Apr 13, 2022 | 06:49 AM
wilcar's Avatar
wilcar
An 85 with a vacuum advance distributor????
Old Apr 13, 2022 | 06:58 AM
krackenvette
Its been a while, thats why I said it. I realized it is the EST that needs to be unplugged. For some reason I thought my L98, in Camaro had it.
Oh well, unlpug est to set timing.
Old Apr 13, 2022 | 01:22 PM
Charles212's Avatar
Charles212
What is the EST? Are you saying that the car timing should be adjusted with the EST vacuum line unplugged? Then once timed, plug it back in and go from there?
C
Old Apr 13, 2022 | 01:39 PM
krackenvette
Its not a vacuum line, just a little plug that is needed to be unplugged to set timing. Then, once timing is set, plug it in and the ECM takes over for driving etc.
https://www.corvetteforum.com/forums...djustment.html
To Idle issues ?
