Knock Sensor Install
Old Apr 12, 2022 | 08:49 PM
mattski11's Avatar
mattski11
Default Knock Sensor Install
I'm installing new knock sensors and got a bit of a newb question...should the knock sensors be tightened to the point where they are flush against the block then torqued to 14 ft/lb.? I've got both torqued to 14ft/lb at the moment but there's about an 1/8th inch gap between the "cup" of the sensor and the block on both. Almost feels like they're just a little hung up on the dried sealant.
Old Apr 12, 2022 | 10:33 PM
78blueta's Avatar
78blueta
If you tighten it against the block you will exceed the 14 ft lbs. You should be good where its at.
Old Apr 12, 2022 | 11:12 PM
mattski11's Avatar
mattski11
Great, thanks!
To Knock Sensor Install
