You could switch to a single throttle body . I’m running a Holley Sniper EFI setup on my 85 and have had no real issues with it .
but i understand it’s not everyone’s cup of tea .
does the dash still work with Holley Sniper EFI setup?
Yes the digital dash will work as normal . The only thing they share is the Tach wire off of the HEI . But putting a Vacuum lockup switch or similar for the torque convertor is necessary because the car will randomly lock it .
I'm looking to buy a 1984 c4 corvette, but I don't want the cross-fire injection; is it possible to swap it for a 1992 LT1 intake manifold?
I like the crossfire. once the fuel pressure is adjustable, ported intake. make the cross section area the same full length of the runner, also those diffusers under tb are restrictive, modify or remove. stock exhaust manifolds are restrictive, can be opened up to a point. welds are huge, there like a .25" wide when they only need to be .125". primary tubes I'm guessing only flow 105 cfm. they should flow 135cfm, not actual number, just use for comparison. stock cat is a restriction and most likely the stock muffler are also. after that it a matter of heads and cam. I don't mined the cam. its a Melling CC-37 259/271 advertised duration, 202/207 @.05 .403/.415 lift with 1.5 rocker .430/.443 with 1.6 rocker.
opening up the intake flow and the exhaust flow, getting the fuel pressure needed with stock cam and head could get you to 280hp.
most of this is labor. lots of grinding. new gaskets. after that its going to to start to costing money. new heads would be next
So, what did you wind up doing? I have a '84 C4 and a '98 C5, frankly, I have no issues with the CFI engine. It starts and runs every time just like the C5. The big difference is the harsh ride of the C4 versus the C5's.
If you're are a broke high school kid you can't afford a 40 year old corvette unless it's inherited. You will like have plenty of worn parts to replace. It's old enough auto shop instructors may not be much help.
With that said before you buy car, have a pre-purchase inspection done and see what kind of shape it's in and what needs fixed for safe operation. If the Crossfire is operating correctly and there is no drivability issues leave it alone. They're easier to screw up than to correct. Stock C4s as a rule aren't rockets they are corner carvers , on a windy road they can embarrass cars with more horsepower. If in the future you want a rocket save you money for a ls swap.
