1995 Opti Spark
Old Apr 20, 2022 | 09:27 PM
Whrabbit's Avatar
Whrabbit
Default 1995 Opti Spark
I know this question has been asked maybe 1000 times. If I need to replace the OPTi what are my choices so that it’s like the original?
i’m starting to notice a small amount of radiator fluid on the floor (tablespoon) and my fear is the water pump. I can’t find the leak on the top. within the next week I’ll have it put up on a lift to look underneath.
by the way I only drive the car 4000 miles a year (84,300 miles on it). Three to five years from now I will purchase a 2010 C6 and sell the car.
Sometimes there is a skip in the motor. It is less than a second. It is random and only notice at idle.
I see accel, msd, and the Chevrolet unit.
Any thoughts on these?
Old Apr 21, 2022 | 10:43 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
So, while you are thinking of another optispark, I found that my water pump started leaking from a gasket, not the weep hole. Your opti may be just fine as mine was.
Is the engine running bad or not at all? Throwing codes? Or are you asking for a preventive measure?
With that, the two I have heard kicked around with the most accolades are the OptiDoctor and Petris.
Old Apr 21, 2022 | 12:19 PM
Ronn38's Avatar
Ronn38
I second Petris-- I believe the OptiDoc has closed shop. From my understanding, the issue with vented opti's is water mucking up the rotor/pick-ups and/or the barring waring out.
If your car is running fine now, you're opti is more than likely fine. Find your leak and fix it, don't fix what ain't broke ;-)
R
Old Apr 21, 2022 | 03:00 PM
Whaleman's Avatar
Whaleman
optisparksolutions@gmail.com
If yours is original I would email Brad the opti doc and literally beg him to rebuild it. Yes, he has closed shop because he can't get enough original pickup sensors. That is what I would do. NOW, if yours has been replaced by a junk one then all bets are off. Dan
Old Apr 22, 2022 | 08:37 AM
captain vette's Avatar
captain vette
I’ve talk with the doc a few months ago he doesn’t want to fix my original opti stating they are too old and brittle to work on I went with Petris and I’m 100% satisfied so far
Old Apr 22, 2022 | 10:40 AM
Whrabbit's Avatar
Whrabbit
Question - What is Petris? Is that a brand or a person who can repair our original Opti?
Old Apr 22, 2022 | 01:24 PM
Whaleman's Avatar
Whaleman
Thanks. I wonder what part is too brittle? He replaces the rotor and cap. Everything else is steel except some interior wiring. Dan
Old Apr 22, 2022 | 05:10 PM
captain vette
Chris Petris he is an authority regarding C4 Corvette, just google Petris Enterprises
Old Apr 22, 2022 | 05:11 PM
captain vette
I know but that was his answer
Old Apr 25, 2022 | 08:51 PM
Whrabbit's Avatar
Whrabbit
I contacted Petris and they are 3 months out and I need to do this soon as it is leaky more. Hopefully they can help as I hate to buy a less quality unit.
Old Apr 26, 2022 | 03:09 PM
Whrabbit's Avatar
Whrabbit
I was able to purchase an opti from chris petris.
Close out discussion
thanks to all
To 1995 Opti Spark
