opti killing me
Old Apr 22, 2022 | 10:08 AM
VETTES14$'s Avatar
VETTES14$
1st Gear
Default opti killing me
hi i have a 1996 base model; corvette lt1 so pulled the first opti out at 8100 miles it was a mistake tyo use same sensor and wheel it still ran rough so i took out opti and throw in garbage spent more on a accel opti installed it and now it runs real bad so check plug wires replaced plugs and wires, coil ,and egr still barely runs starts up idles ok put a load on it and misses real misses real bad any advice . ps. oh ya while installed the alternator the plug got smashed and it arced out just for a second door light didnt work so i checked fuses didnt find blown fuse but then lights came back on in the doors it still runs like crap the guy at oriellys said( time it with a light)how do i time it with out being able to turn distributor im really stuck ps i cant spell real well sorry everyone
Old Apr 22, 2022 | 01:27 PM
Whaleman's Avatar
Whaleman
That is one very long sentence.
PS: Can't time a 96 with a light.
PS2: Don't listen to the experts behind the counter at O'reillys.
PS3: Check for codes with a code reader at O'reillys.
PS4: Report the codes here.
Old Apr 23, 2022 | 03:35 PM
tpi 421 vette's Avatar
tpi 421 vette
I think Accel opti's are junk. I had one that lasted 15 minutes then wouldn't run at all. Since it was under warranty, I tried a second one. After about 500 miles, the second one started acting up.. if the engine was above about 5000rpm, it would misfire and cut out. And when that was happening, the tach would jump around. So the second one was junk too. So now I have an AIP opti. so far its been perfect
Old Apr 23, 2022 | 04:16 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Optis always scared me away from the 91-96 C4s. I had a 89 for a while and I liked the "spin the distributor" simplicity.
Old Apr 24, 2022 | 03:42 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Suspect you mean 92-96 C4s.
Old Apr 24, 2022 | 08:40 AM
BLUDICE's Avatar
BLUDICE
“oh ya while installed the alternator the plug got smashed and it arced out“ I suggest you disconnect the battery before doing any such engine work.
Old Apr 24, 2022 | 11:43 AM
Whaleman's Avatar
Whaleman
Yet another first post where the OP never comes back to see if anyone answers the question. Dan
Old Apr 24, 2022 | 07:11 PM
BLUDICE's Avatar
BLUDICE
he’s a rookie- lol.
To opti killing me
