bad wiring
Old Apr 22, 2022 | 10:04 PM
greengrinch's Avatar
greengrinch
5th Gear
Default bad wiring
Would anyone know What the inline resistor /capacitor is mounted inline between an orange and a lite blue wire found on left side of my steering stalk?
Old Apr 22, 2022 | 10:48 PM
SloJo's Avatar
SloJo
Might help if you told us what year you're talking about!
Old Apr 22, 2022 | 11:40 PM
jv9999's Avatar
jv9999
It might be a VATS bypass resistor.
Old Apr 23, 2022 | 07:16 AM
greengrinch
5th Gear
Sorry it is a 92 coupe with an LT1
Old Apr 23, 2022 | 07:21 AM
greengrinch
5th Gear
No Sir , It already has one of those. This looks factory crimped and soldered . This came apart during alarm removal . The alarm was causing a no pulse condition.
Old Apr 23, 2022 | 08:17 AM
WVZR-1's Avatar
WVZR-1
An after-market alarm or .......
Do you have the FSM for your '92?
You mention 'stalk' - do you mean the directional/cruise/wiper function lever? You had to remove the end cap to gain access?
Old Apr 23, 2022 | 11:35 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by ihatebarkingdogs
It's the capacitor for the high mount brake light, which is the lt blue wire. There is also one on the white wire for the regular brake lights. Both are OEM. They are shown in the schematics for the brake light circuits. It is wired across the contacts of the brake switch to reduce arcing. The brake lights will function just fine without it.
I guess then 'steering stalk' in this case is the 'column'? Interesting
OP if you have the '92 FSM 8A-110-0 and -1 will display those capacitors that are mentioned. 8A-110-1 for the one you specified.
Old Apr 23, 2022 | 08:40 PM
greengrinch
5th Gear
Thanks so much, now I dont have to be so concerned.Thanks for your help.
Old Apr 23, 2022 | 08:44 PM
greengrinch
5th Gear
Yes, true to form Englishmen. But you understood well done. And thanks for the help.
To bad wiring
