Camber Brace Installation
Old Jan 1, 2003 | 09:54 AM
john3154's Avatar
john3154
Default Camber Brace Installation
Installing the Camber Brace yesterday took me 1 hour. It was a tight fit but with my son helping to guide it in, it went in on the first try. I only had to lossen the serpentine belt to remove the control arm bolt. I would suggest removing the harness clips that are attached to the water pump. I broke one of them. I didn't have to use any of the supplied shims. I just have to go out and buy a serpentine belt tool today to re-install the belt. There isn't enough room now to get my breaker bar down past the brace.
This being my first mod(I guess really an add-on), I can't wait to try it out.
Old Jan 1, 2003 | 01:16 PM
STL94LT1's Avatar
STL94LT1
Default Re: Camber Brace Installation (john3154)
You'll love it, makes cornering a blast.
Old Jan 1, 2003 | 01:19 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: Camber Brace Installation (STL94LT1)
It must be harder on the LT1's because of the engine design. On my L98, it took about 10 minutes.
Old Jan 1, 2003 | 09:52 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Camber Brace Installation (Fastguy)
Mine will be in soon!!! Just ordered it the other day!!!!
Hope everyone got in that wanted too.
matt :chevy
Old Jan 2, 2003 | 12:06 AM
Gary04Z06's Avatar
Gary04Z06
Yep, there is more room in the L98. The LT1/4 is a little more time consuming. But well worth the results!! :steering:
To Camber Brace Installation
