[Paging] Marcho Polo
Old Jan 1, 2003 | 12:36 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default [Paging] Marcho Polo
Hi Craig,
Is it possible to send the info for the programming on my chip? I need stuff like engine speed and desired idle. I'm getting a code 44 (lean) on 50 psi. and can't figure it out quite yet. I have the min idle set to 850 and the engine wants to die when I put it in gear. It will go down to 400 rpm and then jumps to 1100-1600rpm.
If you need more info let me know. If you can send the info I can ask BOWTYE8 to read it for me.
Thanks,
John
Old Jan 2, 2003 | 03:00 PM
BOWTYE8's Avatar
BOWTYE8
Default Re: [Paging] Marcho Polo (War Machine)
Hi John,
you on the road somewhat????
What was the verdict on your lifters?? Yep.... if you want Craig wants to forward me the info or updates I will help out and burn them on your prom for you. Help save the cost of shipping back and forth.
Dennis
Old Jan 2, 2003 | 05:54 PM
War Machine
Default Re: [Paging] Marcho Polo (BOWTYE8)
Hi Dennis,
That would be great if Craig can send you the info and go from there. I'm on the road but not running as well as I'd like. Heck, I can't really complain much because the project is only 90% finished. We had to re-clean the injectors to get it running right. The starting fluid got 1/2 of them cleared up enough to get her running when I saw you last. It fired up fine when John sent then out for more cleaning. The lesson I learned here is to have the injectors cleaned during the later stages of this kind of project.
I'm not sure about the lifters either but when I get the info from the chip and install a ratio adapter, we'll have to check the rockers again. John made some nice splash shields for the heads so no more chokin' on smoke! ;)
Thanks Craig and Dennis! :thumbs:
John
Old Jan 2, 2003 | 11:27 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
hey John! Just saw this post.... I'll email Dennis the bin from the chip and if we need to tweak it or whatever we can do that.
Old Jan 2, 2003 | 11:32 PM
Marcho Polo
Former Moderator
Default Re: [Paging] Marcho Polo (Marcho Polo)
Dennis, just sent you an email!
:cheers: :thumbs:
To [Paging] Marcho Polo
