Really stumped with an issue and I've done all the research getting nowhere. By way of background, bought an 87 that was non running and sat for a very long time. Drained the very old gas, put in a new pump/assembly and found out the engine had a knock. Replaced with an 88 and have been driving it. I was having a brake issue and just fixed when this new issue pops up.
Start the car and it takes a couple of cranks but starts fine. Around 30 psi. Drive it and for the first 20 to 30 seconds its fine. Then it will start to bog down. Giving it gas has no effect and it'll putter and back fire then eventually get to speed but if you give it more gas it'll bog down again. Psi drops to 20 at idle when warm. When driving, psi will drop as low as 10 on acceleration. Replaced the pump, pressure regulator, egr, filter with zero results. Upon taking out the old filter, there was a TON of gunk in there and the filter maybe has 100 miles on it. At this point I'm completely lost on what it could be. Car had zero issues before this and its completely spontaneous.
You might just take a look at the new fuel filter you installed as you might find it full of gunk also. If so, the tank would need to be cleaned. I went thru this once with a car I bought. Apparently someone decided to add some sand to the tank. Good luck and keep us posted.
I thought of that but the sock looked good when I replaced with a new pump
If after checking the newly installed filter and finding it clean, I would replace the sock. They can bend restricting fuel flow. However, I still think you've got dirt in the tank.
Could we get an update, please? Such feedback helps everyone.
Haven't had a chance to work on it yet. I have ordered a new sock, yet another pump and a TPS and plan to see if I disconnect the MAF creates a difference. I understand that the filter being clogged isn't good but if that was the culprit I'd have to assume I would have at least gotten a few minutes of run time before it clogged again.
Maybe. I am a bit confused....
Did you ever check the pressure after changing pump/filter, and then running it? Do we know what the fuel pressure is, at this point, when the symptom is occurring?
Yes I checked. The 20 psi is with the new pump, pressure regulator and filter all changed out. Same for the drop to 10 psi when driving with all the new parts.
O.K. That's what I thought, but wasn't sure, the way it was worded.
SO...you don't need a TPS or a MAF. What you need to do, is diagnose why you're only getting 10-20 PSI, b/c that is insufficient and will cause bogging and backfiring through the intake.
How is the hose that connects the fuel pump outlet to the ending unit pipe?
I was going to check when installing the new pump, now 3rd pump in under a year. The sending unit is new. I grabbed an autozone pump to do the last swap but now went gm genuine hoping that would help. Pump doesn't arrive until tomorrow so I haven't taken it apart yet. I didn't notice anything odd when i changed the pump last week though.
You might try running a clear siphoning hose to the BOTTOM of the gas tank and drawing out some fuel to look at. That should show if the tank contains any dirt.
Can you test to determine if it's the filter, sock, pump connection....or keep buying parts, I guess....(?)
Wouldn't have any idea how to isolate that. The only thing that isn't new is the sock, which is only a year old. Everything has been changed with no effect.
Sorry to say, but something is seriously restricting your fuel flow and burning out your pump. 3 pumps in one year is ridiculous. You should have around 40 lbs when you hit the key and the system pressurizes and then low to mid 30s when running. Either you have a huge blockage in the lines, the filter is installed going the wrong direction or you are installing the wrong size pumps.
You need to blow out the lines both ways and confirm even flow. I don't think a faulty FPR would cause a restiction in flow. Rather, it would have no or really low pressure due to a leaking diaphram.
Try those things first and post back.
Ted
It goes down to around 10 psi when driving and holds zero pressure when off, making me think it was the diaphram but changing it out had no change. Im not sure its the pump, just a guess. Filter is on correctly and gas was pouring out steadily when i changed the filter.
That's one way.
You could also devise a "T", install it starting at the rear, then move forward until you find a pressure drop. There are two ways to test...
Pressure loss would not result in burned out pump prematurely. Trying to pump against a blockage would most likely. Even though the line from the tank to the injector rails is flowing freely the return line could be clogged. One thing I didn't mention was the fuel line stabilizer inside the tank. Is that on tight or has someone installed a rubber gas line section in its place to bypass that piece? There is a way to check the return line pressure posted on here if you search.
