rear side markers
Old Apr 27, 2022 | 03:20 PM
Kojowatu's Avatar
Kojowatu
Default rear side markers
Has anyone removed the passenger side rear side marker lens? Mine is cracked and blowing bulbs.
Old Apr 27, 2022 | 03:41 PM
s carter's Avatar
s carter
To remove there are a couple of 7mm screws along the edge and 2 wings that fit into tabs in the 1/4 panel remove screws and wiggle out of the tabs and most of the time they don't just fall out
Old Apr 27, 2022 | 03:45 PM
Kojowatu's Avatar
Kojowatu
How do you get up in there? It is not as open as the driver side. I can get to the forward nut but not to the rear oone
Old Apr 27, 2022 | 04:51 PM
s carter's Avatar
s carter
it's not totally easy you can either donate skin off your arm squeezing between exhaust or remove the Y pipe or at least loosen it from the two rear hanger points let them hang. or remove tire and inner fender, been 35 years since I had need to remove those assemblies a long extension with a Swivel end
Old Apr 27, 2022 | 04:59 PM
Kojowatu's Avatar
Kojowatu
Thanks for your quick response and I will give it a try.
Old Apr 27, 2022 | 08:23 PM
DWAVette's Avatar
DWAVette
I just changed a bulb on the rear passenger side on my 91. Crap - that sucked.
There is a splash shield that needs to come off then you can barely run your arm up there.
To rear side markers
