Wiper switch
Old Apr 27, 2022 | 05:54 PM
d096819's Avatar
d096819
Default Wiper switch
How do you check a windshield wiper switch to see if it is bad.
Old Apr 27, 2022 | 07:31 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Swap it with a switch that is known to work.
Old Apr 27, 2022 | 10:44 PM
d096819's Avatar
d096819
Hate to spend the $100 and find out the switch is hood then not being able to return it since it is an electrical item
Old Apr 28, 2022 | 08:56 AM
SH-60B's Avatar
SH-60B
Unplug the wiper motor to see if you get 12 volts, with a meter or a simple light, when you actuate the switch. Then check the ground as that is most often the culprit of electrical problems.
not on a corvette but I have had non functional wipers due to cracked solders in the pulse board on the wiper motor.
Old Apr 28, 2022 | 09:58 AM
d096819's Avatar
d096819
Old Apr 28, 2022 | 12:36 PM
FostersPerformance's Avatar
FostersPerformance
What year, and whats it doing/not doing?
Old Apr 28, 2022 | 12:52 PM
d096819's Avatar
d096819
85 C4 no response from wipers when I turn them on at the switch. No motor noise such as hum rither
Old Apr 28, 2022 | 02:47 PM
NavAir's Avatar
NavAir
I am assuming that you have already checked the fuse...
Old Apr 28, 2022 | 03:05 PM
d096819's Avatar
d096819
Correct
Old May 5, 2025 | 05:46 AM
schepp88's Avatar
schepp88
4th Gear
Find the schematic of the switch then you can ohm out each pin to the 12v input pin. Basically, clip your meter leads to the 12v terminal and one of the other pins, check the schematic to see which switch positions it should be open and closed and test it that way. I used that method to find out my c4 has a switch from a different model (the pulse signal terminal had 24k ohms on OFF and HI when it should have been open on those 2 positions).
To Wiper switch
