Idle issue/back fire
Old May 2, 2022 | 03:28 PM
Yonker's Avatar
Yonker
Default Idle issue/back fire
I'm looking for some knowledge as to the idle quality of an LT1 after performance parts and before a tune. I just finished installing AFR 195 heads, had my intake port matched, BBK 52mm throttle and 1.7 roller rocker arms installed over the OEM cam. It has not been tuned yet, but it is experiencing a back fire and idles like it has a choppy cam in it. Is this normal until it can be tuned or am I missing something?
Old May 2, 2022 | 05:00 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Vacuum leak?
Did you get the opti wet?
Old May 3, 2022 | 06:47 PM
Yonker's Avatar
Yonker
No, the opti stayed dry, and I know a vacuum leak can cause a rough idle but I've never seen a vacuum leak cause popping in the exhaust. I appreciate the help. Guess I'll wait for a tune to see what happens.
Old May 3, 2022 | 08:09 PM
FrankieD's Avatar
FrankieD
Have you verified that the spark plug wires are in proper sequence
Old May 3, 2022 | 09:47 PM
Yonker's Avatar
Yonker
Yes, I checked all from the Opti to each plug (twice).
To Idle issue/back fire
