91 Not start after rebuild
Old May 9, 2022 | 01:39 PM
kuja53's Avatar
kuja53
6th Gear
Default 91 Not start after rebuild
So I rebuild my engine top parts (heads, lifters, injectors, EGR valve, rockers). And after I put it all together I try to start the engine. But currently the engine cranks but no start. I check if there is spark on spark plugs and I have spark. A also change distributor cap, spark plugs, spark wires. I check fuel pump relay and fuel pump. It works. On-board diagnostic has C12 so no issues. So my assumption is that there should be error with timing. But I didnt find what is initial procedure of how to set timing after you remove distributor. Weird is that I check all the electrical harnesses, all fuses and everything is ok. And also I would like to know some hints where should be problem. Thank you.
Old Jun 16, 2022 | 12:55 AM
vinco's Avatar
vinco
I agree your issue is most likely distributor position and/or position of the plug wires.
TDC on the compression stroke on #1 is what you need to stab the distributor. You can you toob that. Firing order is 18436572.
