Questionable Fuel Injectors for 89 C4
Old May 12, 2022 | 03:55 PM
C4CPTX's Avatar
C4CPTX
Cruising
Default Questionable Fuel Injectors for 89 C4
Hello, Mike here, new to the forum and to the Corvette world. Recently bought my tired C4 (field find) for 4k and hoping to bring her back to life on a budget. My first big project is replacing the fuel injectors which I found on ebay, but I am hesitant to believe the seller that these are a fit for any Chevys at all. When I Google "0280150943 bosch fuel injectors" I get a whole lot of Ford related results. Has anyone ever used these on your Vette? Thanks in advance for any feedback!
Item specifics
Condition: Remanufactured
Seller Notes: “Please check pictures showing in the listing and refer to part numbers in the description before bidding .”
Superseded Part Number: 128514231, 85-92 Corvette Camaro 5.0L 5.7L
Modified Item: No
Custom Bundle: No
Core Charge: None
Interchange Part Number: Firebird, 128514231, 85-92 Corvette Camaro 5.0L 5.7L
Number of Pieces: 8
OE Spec or Performance/Custom: Performance/Custom
Manufacturer Part Number: 0280150943
Other Part Number: #152 Corvette Camaro Firebird
Brand: OE+
Fitment Type: Direct Replacement
Non-Domestic Product: No
Manufacturer Warranty: 1 Year
UPC: Does not apply
Old May 12, 2022 | 05:40 PM
Moved to C4 Tech.
Old May 13, 2022 | 01:57 PM
Blue Bucket List's Avatar
Blue Bucket List
Check out this post. Will give you some good info.
https://www.corvetteforum.com/forums...92-lt1-c4.html
Old May 13, 2022 | 02:41 PM
topfuel67's Avatar
topfuel67
Those injectors seem to be the older style body, but the 4 hole pattern where the older style body is usually a single hole. I have read of recommendations on older cars to upgrade to the newer style injector like the Bosch III. Not only is it a 4 hole, but it is a more efficient design. I would look at these injectors for your 89. I'm not 100% sure, but I think these are the ones for you. Part number Bosch 0280155710. Those are rated at 20 lbs, 14.5 ohms. I see them around $50 for a set of 8 on ebay.
Old May 13, 2022 | 10:02 PM
jts90vette's Avatar
jts90vette
2021 C4 of the Year - Unmodified Finalist
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
Call this place Fuel Injector Connection - High Performance Fuel Injectors ask for Jon. Bosch 3 is what you want.
Old May 13, 2022 | 11:38 PM
C4CPTX's Avatar
C4CPTX
Cruising
Duplicate
Old May 13, 2022 | 11:41 PM
C4CPTX's Avatar
C4CPTX
Cruising
Thanks for the info! I agree on upgrading to new injectors. Definitely returning the ones I have.
Old May 13, 2022 | 11:43 PM
C4CPTX's Avatar
C4CPTX
Cruising
Thanks for the contact! I will reach out to John.
To Questionable Fuel Injectors for 89 C4
