Wont start
Old May 13, 2022 | 03:19 PM
hsomanley's Avatar
hsomanley
1st Gear
Default Wont start
I am new here. I have the opportunity to buy a 1984 Corvette. The problem is that it wont start. The battery has never been dead and stays hooked up. Cranks over and has power. The interior lights come on and the security light blinks till you shut door and then goes off. Any suggestions will be helpful. Thanks
Old May 13, 2022 | 04:50 PM
corvettenorway's Avatar
corvettenorway
fuses for the fuel , or ignition modul
Old May 13, 2022 | 09:14 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Not necessarily in this order...
Fuel
Air
Spark
Timing
Old May 13, 2022 | 10:49 PM
glenx122's Avatar
glenx122
Spray some "quick start" into the throttle body.
If it turns over you have a fuel problem.
If not its most likely an ignition problem
Old May 14, 2022 | 07:14 PM
Incorvettei's Avatar
Incorvettei
Sounds like a problem with the injectors not getting fuel pressure. Have you checked them ?
To Wont start
