High consumption problem - 12 mpg
Old May 16, 2022 | 07:09 AM
juni78's Avatar
juni78
Default High consumption problem - 12 mpg
I have C4 1994 LT1 engine with manual transmission. Mileage 190k. Mostly stock, with cold air intake (forced air), custom headers and blocked EGR.
The car was sitting long time before I bought it. Now it is in quite good condition, only vacuum lines are worn and have significant leaks. No codes or lights. Idle slightly fluctuates when cold.
This weekend I made a 300 miles trip (city and highway). The trip was fine, but average fuel consumption was very poor - 12 mpg (even I was driving smoothly). Highway consumtion was 15 MPG.
Do you have any idea what could be wrong?
Old May 16, 2022 | 07:23 AM
Whaleman's Avatar
Whaleman
Are you saying the vacuum lines are worn and have leaks? I would fix that first. Dan
Old May 16, 2022 | 09:00 AM
novaks47's Avatar
novaks47
Have the spark plugs been changed recently? Air filter clean or replaced?
Old May 16, 2022 | 09:43 AM
juni78's Avatar
juni78
Thanks, maybe I will start with this. It shall be done anyway.
Old May 16, 2022 | 09:45 AM
juni78's Avatar
juni78
Yes sir! These parts were maybe my first done when i took it to my garage. In one month I am going to change water pump, optispark, timing chain and all seals and gaskets around it.
To High consumption problem - 12 mpg
