L98 running rich
Old May 18, 2022 | 12:44 AM
Primos's Avatar
Primos
4th Gear
Default L98 running rich
I have a 88 l98 in my 86 TA and she is running rich. I have been through the thing over and over. Changed many parts that i thought could be causing it and still rich to where i have some smoke and raw gas smell out the exhaust. Any ideas or help greatly appreciated.
Old May 18, 2022 | 01:13 AM
Primos's Avatar
Primos
4th Gear
TPS, plugs, wires, distributer cap and rotor, ICM, CTS, all new. Have a code 45 (rich condition) so im guessing 02 sensor is good. Have checked the injectors all seem to be working correctly. Only thing havnt replaced is mass air flow sensor but dosnt seem that old.
Old May 18, 2022 | 07:04 AM
ex-x-fire's Avatar
ex-x-fire
Check the fuel pressure and bleed down rate.
Old May 18, 2022 | 10:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed, if FP is too high it will cause rich running.
Pull, say, #1 spark plug to see if it shows rich running, just for verification.
Old May 19, 2022 | 01:02 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Are the injectors new? If so, are they the right size? If not, know L98's only monitor DS exhaust. If 1-2 injector(s) are malfunctioning, the ECM will fatten up the fuel -- even if the other 6-7 injectors are performing correctly. Check injector Ohms to make sure they are all the same (16 Ohms IIRC)
You could also have a "stuck" injector
Old May 19, 2022 | 01:08 AM
Primos's Avatar
Primos
4th Gear
Injectors arnt new and havnt checked the ohms only did the old broom stick trick and they all seem to be ticking the same. Will check ohms tomorrow. Thank you guys
Old May 19, 2022 | 02:35 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Disconnect the vacuum hose to the fuel pressure regulator and make sure there is no fuel in the hose. If the diaphragm in the fpr is leaking, unregulated fuel can be introduced into the plenum near the 6 and 8 intake runner. Pulling 6 or 8 spark plug may indicate rich running condition in this case. By design, I don't foresee a fpr failing in which normal operating fuel pressures will be exceeded causing a rich condition.
Old Jun 3, 2022 | 09:26 AM
Primos's Avatar
Primos
4th Gear
Fp is at 41 with key on not started. After 20 mins was bleed down to 10
Old Jun 3, 2022 | 01:33 PM
ex-x-fire's Avatar
ex-x-fire
Looks like they are bleeding down, but not fast. Injectors might be dirty but I bet there's other issues.
Old Jun 5, 2022 | 10:29 PM
wsherrard's Avatar
wsherrard
You mention this is an engine swap. Has it ever worked or is this a problem that developed after a period of having worked fine?
To L98 running rich
