88 Hard Brakes
Old Jan 2, 2003 | 11:26 PM
Bamvette98's Avatar
Bamvette98
7th Gear
Default 88 Hard Brakes
Any ideas as to the cause of hard brake pedal. Really have to get on them to come to full stop. Pads still look ok and fluid is ok.
Old Jan 3, 2003 | 12:10 AM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: 88 Hard Brakes (Bamvette98)
Vacuum leak, or the booster is going bad. Check the hose from the booster to the plenum.
Old Jan 3, 2003 | 06:10 PM
Rick86's Avatar
Rick86
Sounds like power booster is bad. Can you hear a hissing sound down around the pedal? Power booster is not hard to replace and doesn't require bleeding the brakes afterwards. Expect to pay about $100.00 for a rebuilt booster.
Old Jan 4, 2003 | 07:21 PM
Bamvette98's Avatar
Bamvette98
7th Gear
Default Re: 88 Hard Brakes (Rick86)
So far both response lead to power booster. I will check that out first.
Thanks for the help. :seeya
To 88 Hard Brakes
