1985 Corvette ZF6 Swap
While doing the 6 speed swap, also installed a D44 and grabbed the correct length driveshaft and D44 c-beam
One of the unusual parts of this swap was the requirement of a bellhousing spacer plate to allow enough room for the hydraulic throw out bearing to operate.
The instructions I was given stated I may need to use as thick as a 0.40" spacer plate. From my measurements 0.125" seemed to work fine, plus I was worried about C-beam fitment issues so I wanted to use the thinnest spacer possible.
I suspect a correctly machined flywheel would have been a better way to go, but since I already have these parts I am going to try to make it work. My Corvette has already been apart for over a year now while I addressed other issues, so I really want to get this thing driving again.
As you can see in the picture here, I am just about half a hole off with a D44 c-beam. I am assuming my best option would be to drill the D36 c-beam, factoring in the spacer plate thickness.
One thing I have not tried yet is loosening up the D44 to see if I can get the bolt hole closer to lining up. I had to install the rear to transport the car so it was snugged up without any other driveline components. I don't think that will be enough movement though, and I can't bring the trans up any higher without getting too close to the floor.
If anyone has some better ideas I am all ears. I thought about slotting the holes in the D44 beam, especially since I am using c-beam plates from ZF-Doc, but it still sounds sketchy and it would be messed up to modify an already scarce part.
The best part of this swap is that I am using an unknown condition ZF6 and D44, so it very well could be coming back out again.
I've done the swap on a 1986 but I used a single mass Fidanza flywheel, Spec clutch friction plate with damper springs, and the Valeo type pull style clutch. That 0.125 is certainly not helping.
I think I'll try to loosen up the batwing next and maybe lift the trans just a little bit more and see what happens. As much as it sucked to put the c beam in, it wasn't as bad as I expected, so no big deal if I have to take it back apart again.
Is your 86 a 1 piece RMS or 2? I know that was part of the issue with my setup, bolting the trans up to a two piece RMS engine. I am sure by now someone makes a flywheel that will work, but I think the guy who put this kit together had to have something custom done at the time.
This is also my first time messing with a stick shift, so it has been a slight learning curve figuring out the clearance needed for the hydraulic TOB. I kept double checking to see why I would need 0.40" of spacer and it didn't make sense, even factoring in wear tolerance.
I was also told I needed to cut the input shaft guide tube to allow the splines to fully engage with the twin disc clutch, but I left it alone. I think there is plenty of clearance between the clutch disc and the guide tube but I guess I'll find out soon enough.
Just glad it worked out. Now to get the clutch hydraulics done and get the car ready to fire so I can find out of it is all coming back apart or not
I ordered one more adapter fitting to see if I can make this work. I realize the original setup was tubing with metric fittings and a bubble flare at the end, I just figured I could adapt the master directly to AN without having to use tubing in between.
I have a Tilton 75-812 master cylinder with 13/16" bore but I wanted to try a stock setup first. I have an adapter plate for the Tilton but I need to machine it a bit to get it to work. I also would need to cut the stock pushrod and cut threads into it so that I can make it work with the Tilton. I wish I just bought the After Dark Speed setup from the beginning. After the hassle of trying to piece this together the $400 price tag is starting to sound like a deal.
I was able to bleed the TOB enough to disengage the clutch, which is a relief because I was half expecting to be pulling the trans back out at this point. Once the clutch fitting is figured out I can get the car ready to start and run it through the gears while it is up on jackstands.
I can't believe this clutch and transmission work but it seems like I was able to go in every gear without issue. I was expecting the clutch to be worse but it's not too bad. I guess I must be a wuss because I have just the right amount of travel and pedal effort with the stock master cylinder. I see no reason to go with the 13/16s Tilton in my application. I have the clutch master spaced out so that the clutch and brake pedal are even, and I added an After Dark Speed pedal stop so that I don't over extend the hydraulic TOB.
This car is a million times more fun with the 6 speed and I can't wait to get it all put back together.
