Throttle Body Coolant Passage Gunk
Old Jun 21, 2022 | 10:49 AM
rayosequis's Avatar
rayosequis
Default Throttle Body Coolant Passage Gunk
Hello,
I am working on my '96 LT1 auto and pulled the throttle body to clean it up replace the gaskets. The coolant passage, unfortunately, looked very rough (pic attached).
I am replacing the water pump, radiator, hoses, etc. but does anyone have any suggestions of what else I should investigste/clean before reassembly? I am leery to install the new parts with how this looked.
Old Jun 21, 2022 | 10:57 AM
383vett's Avatar
383vett
Just bypass it.
Old Jun 21, 2022 | 01:09 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
What does your coolant look like?
Old Jun 21, 2022 | 01:55 PM
rayosequis's Avatar
rayosequis
It was mainly water, unfortunately, which prompted me to replace nearly all components of the cooling system. I'll be pulling the intake manifold eventually, but have not got that far yet.
Once I saw this, I was wondering where else this gunk/residue may be. 🤔
Old Jun 21, 2022 | 02:44 PM
Jud Chapin's Avatar
Jud Chapin
I suspect that’s your problem, running straight water, as it promotes rust. Once you get things cleaned up, including having the radiator professionally flushed and pressure tested, run a 50/50 mix of the proper coolant and distilled water. Distilled water is important as it contains no minerals.
Old Jun 21, 2022 | 03:03 PM
InfomanSS's Avatar
InfomanSS
Pull knock sensors from the block to help get sediment flushed out from there. Pull heater hoses from heater core and reverse flush it...handy tool: https://www.summitracing.com/parts/lil-60900
Old Jun 21, 2022 | 04:10 PM
rayosequis's Avatar
rayosequis
Thank you for the info!
Old Jun 22, 2022 | 07:01 AM
scorpiofox69's Avatar
scorpiofox69
Flush the system and do the by-pass mod.
To Throttle Body Coolant Passage Gunk
