Simple Crossfire upgrades
Old Jun 21, 2022 | 04:07 PM
wxdude10's Avatar
wxdude10
2nd Gear
Default Simple Crossfire upgrades
Hi everyone,
I have an 84 Corvette that I am working to get it back on the road and cleaned up. I know the crossfire injection warts and all. I wanted to see if anyone had any simple, low cost upgrades to get a little more out of the current setup. Like, one idea I had was, is it possible to swap out the crossfire manifold/TBIs for a more traditional intake with either the 350 or 454 TBI units from the pickup trucks? Would it be pretty plug and play from the injection/computer side or is it so very different that it couldn't work?
My thinking was that the biggest limitations are in the intake. I know I could spend a ton of time with a grinder to make it better, but is there some other intake that would work with the truck TBIs that could reduce/remove some of the limitations with the crossfire? A little bit of junkyard diving and swap meet wheeling and dealing to lead to an intake upgrade.
Anyone have any thoughts?
Thanks!
-Mike
Old Jun 21, 2022 | 04:20 PM
topfuel67's Avatar
topfuel67
I recently bought a project corvette that the PO was preparing to do a custom engine using junkyard parts. He was planning on using the 062 heads from the 96+ trucks. Those are about the best cast iron sbc heads chevy made. They require the vortec intake manifold or style. With your crossfire it may be able to run a 96 TBI intake as those are a single injector. I'm sure it would take some playing with, but to run a full TPI set up on your 84 would take a lot more. From what little I know about the crossfire it is 2 TBI carbs.
Old Jun 21, 2022 | 05:39 PM
84 4+3's Avatar
84 4+3
A TBI intake would be marginally better. You'd probably have to extend or change harness ends for TPS sensors and perhaps the IAC but the CFI ecm should run a TBI without too much issue... That being said a later 7747 ECM would also be better... I'm unsure if the TBI fits under the stock hood either. Then you need to figure out an air cleaner.
All that for what would probably amount to 30 HP if that. Iirc the stock TBI engines were rated around 210.
Personally the intake and heads can flow more than what the engine makes in stock form. Case in point i was able to put down 275 through the stock induction setup. Obviously with exhaust, heads and the like but the intake could gain some with the typical rockers, bumped fuel pressure, and tweaked timing...
That's about the simplest where you'd actually notice a difference without the wallet being significantly lighter imo...
Old Jun 24, 2022 | 07:44 PM
mike1111's Avatar
mike1111
Originally Posted by wxdude10
Hi everyone,
Thanks!
-Mike
with stock heads and cam. crossfire intake manifold only needs the runners imperfections cleaned up. modify or knock out diffusers under TB. install higher pressure fuel pump, set pressure to 13psi. I personally like crossfire, it has equal length runners, low profile, can be ported. not sure how much of a gain switching would be. I personally think the diffusers are a big restriction but can't prove it.
To Simple Crossfire upgrades
