Wire help on 94 Generator plug wire
Old Jun 23, 2022 | 01:10 PM
Pokky's Avatar
Pokky
Default Wire help on 94 Generator plug wire
I broke the plug wire coming off the generator on my 1994 corvette. I was in the process of removing the wires from the plug, and it fell apart in my hands. So my problem is that the plug is labeled S F L P, S is the red wire, but F and L are just brown wires. I've dug through my service manual, and there isn't anything on the wires. How do I figure out which brown wire goes where?
Old Jun 23, 2022 | 06:02 PM
WVZR-1's Avatar
WVZR-1
Don't have one here to look at but isn't the 'L' a .8M/18 AWG and the 'F' .35M/22AWG? Are you cutting/splicing a connector or going to attempt to just transfer terminal to the new connector?
Old Jun 25, 2022 | 01:39 AM
Pokky's Avatar
Pokky
I'm transferring the wires to the new GM plug, The larger red with is fine, the problem is the next two brown wires, both small gage and both just brown. I did find it in the big red book, it shows one wire going to the OB1 port and the second one going to the transition controls. The book said both wires send out a signal; telling the commuter that the engine is running. my hope is that sense GM used the exact same wires, there not that concerned.
Old Jul 7, 2022 | 09:44 AM
Pokky's Avatar
Pokky
For others info, car doesn't seem to care which order the two brown wires in.
To Wire help on 94 Generator plug wire
