Skid pad test C4 with modern rubber
i believe a c4 , with z51 or z07 package would match a c8, on the skidpad, if the same tires/wheels (as the c8) were installed.
that said, the c4 suspension has its flaws.
It telegraphs potholes and road irregularities from one side of the road to the other side of the car (my belief is thru the transverse spring)
my old 2004 bmw 330i with zhp performance package felt way more buttoned down on ohio’s typical patched potholed roads
however, on a smooth racetrack, the c4 would outgrip it (generate more g’s) with its wider tires. In my case 275/40r17 on the fronts and 315/35r17 on the rear
I also have the ZR1 tire combo (like Admiral). Just got home with Michelin Pilot Sport A/S 4's mounted. I didn't have time to test them a bunch, but my first impression is very good. Somehow, they manage to feel firmer, but still "soft". (New tires..ya know!). The steering feels tighter than the Sumi's I took off. Less "lag" in turns. Very smooth on the hwy too. Can't wait to challenge them a bit. Has a bit more of that go-kart feel -- which is GOOD!
- There is no such thing as "over-tired for the weight." The lighter a tire is loaded, the more lateral and longitudinal grip it provides. That is a fundamental tenet of suspension design, tuning, and dynamics.
- There's no more "telegraphing" of irregularities from one side to the other with transverse-sprung car than with a car that uses coil springs. Wheel rates are whatever they are, regardless of whether they are provided by a coil or transverse spring or a sway bar.
Suspension does matter, and the C5 and up are better in this department than the C4. The rear suspension of a C4 is probably a bigger compromise than the front, but the front has some issues, especially in the 88-96 models. This basically means the tires aren't always aligned to the road in the best way possible. The C5+ also has a bit more rearward weight bias, which generally helps lateral grip. Finally, the C5+ have wider track widths, which helps lateral grip.
All that said, you can get C4 to generate impressive skidpad numbers with the right tires, and you can fit a lot of tire under a C4 at both ends. The OP's issue is that there aren't a lot of really high-grip street tires in his sizes. However, put a set of Hoosier A7s in stock sizes on that car and it will have grip for days. I did some autocross events on 315 Hoosiers at both ends of my C4 and it was sublime. Best time ever! I don't think skidpad numbers are the most important aspect of road course performance, though. The place where modern cars have improved the most is in transitional handling and when combining inputs such as braking or accelerating while cornering.
Found this Car and Driver article. 1.01g with now terrible compound goodyear garorbacks. Just makes you wonder about modern tire capabilities on the C4.
Tires have a ton to do with it. What's on your car now? Also, what year and wheel size(s) do you have? If you can tell us how you plan to use the car, we can provide some recommendations for good tires. For shocks, instead of the Bilsteins, you may want to consider the Ridetech HQ single-adjustable shocks. They are really high quality monotube Fox dampers with easy-access adjuster ***** (unlike the rear Konis for this car), and they have good damper curves for a range of stock C4s (including the Z51s with "challenge" spring rates). OTOH, if you might go with coilovers anyway, just hold off on purchasing shocks. The Ridetech coilover setup is a great option for that, btw.
Finally, if you're at all interested in really exploring the limits of your car, I strongly suggest finding some local autocross events in your area. You can really wring the car out safely there, and you'll learn a ton about vehicle dynamics along the way. You'll also see a wide range of tires at all performance levels so you can get a better idea of what you might want to use.
If you really want to prep your car for 450hp, you should probably wait on shocks and get a good coilover setup. You'll want stiffer springs than whatever you have right now, and as I wrote before, that's about the only way to go about it these days. You'll want stiffer damping rates to go with them, too. 450rwhp is a lot of power, more than most people think. I don't think my C4 had that much (it's a 396 with around 420rwhp) and people who rode in it always thought it had 600hp! In reality, it was a touch faster from a roll than a stock C6 Z06, which is still fast. It was fun, and still streetable, with a very wide powerband.
as a guy who is in the process of learning to be an amateur racer, my unsolicited advice right now to forget about hp for now. learn car control first. a decent driver in a miata will be faster than you for the first couple years. that is humbling. your ho doesnt matter right now.
Running my c4 down a road where the ride side is patched potholes throws me all over the place
where as in the bmw , it felt more buttoned down to the road and less scary to drive fast around hills/corners
on a smooth racetrack, the opposite is true on my c4 (the c4 was less scary to corner fast in)
I have a race in 6 days and a set of brand new 315/35R17 Nitto NT05 (not the R version) on all four corners and I am interested to see if the increased grip will help in the corners!
does the race series you compete in limit you to 200tw? Thats pretty normal actually and in my series it is also limited to 200tw. (Champcar, Luckydog)
I currently have the 555’s on my zr-1 and just got home from a monster track day and i pushed those things way way beyond grip. i wanted nt-01’s but none available.
lets us know how the nt05 compares please!
