Odd event - VATS? KEY?
I checked resistance on both keys after coming into the house, searching here for 20 min (ie the key had time to cool down).. and they both read 7.4 ohms. Went out to the car, and it started.
So, Im wondering if the heat changed the resistance of my key enough to throw it off and turning it over and over put the vats into a temporary lockdown mode which is why my spare didnt work?
Anyone have a thought on this?
Im going to put my key in the sun right now for 30 min and see if I can reproduce.
Now Im worried about reliability which is why Id like to prove my theory. On the other hand, with a 26 yr old car with original plugs and wires I SHOULD be worried
My biggest concern is, I have a dog seat with seat belt and like to take my boy out with me and Id be very upset if I got stranded on a 96f day.I have a Tech 2 scanner (IE GM diagnostic), would I see this event? I may try it.. its the chinese knock off and reqiures a laptop so a pain to get running when Ive not done it in awhile.. but may do so.
EDIT: Heated up the key. Could not reproduce.
Is it damaged? I don't think so and I would run it as you're normal key with the backup in you're pocket for a week or 2 but I think your or OK
I could even be that heat in the steering column caused enough expansion (in the ignition) to prevent pellet/VATS-circuit contact? FWIW, resistance goes up in wire as it ages. If you wanna guess [pellet] resistance rises with temp, include car wiring in that "equation".
EDIT: Maybe it's possible the key got damp/wet though?
Anyway... I dont know what is going on. I do have a check engine light on.. I pretty much know what it is.. its the secondary O2 sensor just being stupid again.. it just does that from time to time and probably needs to be changed out or maybe I am running rich.. who knows.
I think what I should do is document the key bypass procedure.. not sure how that works.. I guess Id need a 8ohm resistor (in my case) which I should have on a shelf. Keep that in the console compartment.
Its interesting that it happened and then unhappened. Maybe I will try heating up the key one more time and check resistance myself rather than see if the car starts. Too late in the day now.. maybe tomorrow.
https://www.lockmasters.com/site/pdf...%20Article.pdf
Learning how to understand what the VATS system is saying
Ledger Articles - 2007 By Steve Young
The VATS system can only communicate with you by way of a light on the dash or in some cases a text display on the dash. If you want to be successful, you need to learn how to interpret what the VATS system is trying to tell you. The light on the dash that the VATS system uses is usually called the “Security Light” because it usually says “SECURITY.” On some cars it may say “ANTI-THEFT” or just “THEFT.” If you know how to interpret the security light you can tell a lot about what the VATS system is doing and save yourself a lot of time and trouble. Below is a simple guide to reading the security light.
If the light does not come on – This means that the system is not working. The problem may be a bad connection, bad wiring or a bad module, but until you get the security light to come on you are wasting your time attempting to interrogate the vehicle.
If the light comes on and stays on as long as the ignition is turned on – This means that the VATS system is working and it read the resistor value you tried, but rejected the starting attempt because you did not use the correct value. When you see this response, you need to turn the switch off and wait at least three minutes before you try another value.
If the light comes on briefly and then turns off – This indicates normal operation with the correct key. The car should now start. If the car does not start, it is not because of the VATS system; begin looking of after-market alarms or other problems.
If the light blinks – This usually indicates that the vehicle has a factory alarm system and that the door is open. If closing the door causes the light to stop blinking, continue. On some vehicles however, a blinking light with the door closed means the same as when the light does not come on – see above.
If the light comes on and stays lit even after the ignition is turned off – This feature is not found on many cars, but when you do find it you are in luck. The security light on these vehicles acts as a timer for you. When the light goes off, it is time to try the next value.
