Enquiring minds need to know
Old Jul 6, 2022 | 11:34 PM
Gypsy Rose's Avatar
Gypsy Rose
Default Enquiring minds need to know
Been chasing ghosts in my VATS for several years. I've decided that rather than disabling VATS , I want to install a manual bypass switch. My question relates to choosing the correct resistor for the application. In a '93 does the ECM / VATS read actual resistance or voltage drop due to resistance?
Old Jul 8, 2022 | 10:42 PM
Gypsy Rose's Avatar
Gypsy Rose
OK , 95 views but 0 replies. I'm not trying to be a geek here and I do know how to find the correct resistance value from my keys. The reason for my question is to determine the best wattage rating for the resistor that I will install . I know that I could easily buy a pre-made per GM code value plug it in under the dash resistor on Ebay or Amazon but I'd rather use a high efficiency 3 position switch so I can select normal operation / bitch ain't gonna start / VATS bypass.
Old Jul 8, 2022 | 11:16 PM
ToniJ1960's Avatar
ToniJ1960
When youre using k ohms 1/4 watt is fine unless theres high voltage in the circuit. Mine is about 11k I used 1/4 watt 1/8 would probably be fine even
To Enquiring minds need to know
