Ecm reprogram
Old Jul 7, 2022 | 04:58 PM
Mike Clouston's Avatar
Mike Clouston
3rd Gear
Default Ecm reprogram
I want to get my ecm reprogrammed in my 86 corvette without the vats in it can anyone recommend a place that does this thanks
Old Jul 13, 2022 | 12:21 PM
vett383's Avatar
vett383
im pretty sure the VATS are in the CCM, least in mine which is a 1990 it is
Old Jul 13, 2022 | 12:58 PM
Scott Rasmussen's Avatar
Scott Rasmussen
VATS is in the CCM, why not just do the VATS bypass?
Old Jul 13, 2022 | 04:51 PM
Kevova's Avatar
Kevova
86 does not use CCM that's 90-96. It uses a vats module. Vats disable is commonly done by soldering in resistor equal to key values in key reader circuit.
It could be done with a new prom and some rewiring bypassing starter enable relay.
Old Jul 13, 2022 | 08:54 PM
dieselgeek's Avatar
dieselgeek
http://tunedperformance.wordpress.com
Old Dec 9, 2022 | 01:04 PM
Roger Fairchild's Avatar
Roger Fairchild
8th Gear
I did a code 4 bypass off the steering column and the same problem exists. Sometimes it starts, when it doesn't, u have to an hr before it starts.
Old Dec 9, 2022 | 01:17 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^These guys are right. No CCM in '86.
What does the security indicator on the dash do, when it won't start, with the key in the "RUN"/on position?
Old Dec 10, 2022 | 05:10 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
And as there is no CCM, there is no connection between VATS and the security indicator. In ‘86-‘89, the security indicator is driven by the UTDS Module and only indicates the status of the Theft Deterrent System.
Old Dec 10, 2022 | 09:40 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Are you saying that in an '86 car, the security light doesn't blink when you get in the car but don't insert the key?
Old Dec 10, 2022 | 01:54 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
No, what I’m saying is that SECURITY indicator is only connected to the UTDS on ‘86-‘89. It lights to indicate the status of the Theft Deterrent System. Blinking indicates that a door is opened and the Theft Deterrent System is not armed. Once armed SECURITY indicator lights solid. No connection to VATS until 1990 and the CCM. The UTDS and VATS module’s functions were incorporated into the CCM. As the CCM drives the SECURITY indicator, it could be used to indicate more than just the status of the alarm and could also indicate the status of VATS.
Old Dec 10, 2022 | 03:50 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
So on an '86, you get into the car, close the door, don't put the key in the ignition....and you got NO security light. Is that right?
That doesn't seem right....
Old Dec 10, 2022 | 05:19 PM
johnfin's Avatar
johnfin
Default 85 security
What do 85 cars have for security?
Old Dec 11, 2022 | 03:07 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Like the ‘86-‘89, but with no VATS. The difference is on the ‘84-‘85, the UTDS outputs not only to the horn, but to the starter relay. The SECURITY indicator works the same. When the alarm is active on 84-‘85, the horn beeps on and off 50 times a minute and the starter is disabled so the car won’t crank. On ‘86-‘89, when the alarm is active, the horn beeps on and off 50 times a minute, but if VATS is happy the car will start and you can drive down the road with the horn beeping on and off.
To Ecm reprogram
