I’ve recently started having a code 33 issue on my 1985 manual Corvette. It’s been intermittent but getting much more frequent to the point that I need to deal with it before I can trust the car.
A few points:
when code is thrown, it runs like garbage up to 1/4-1/2 throttle, like I’m not even pressing the pedal. Then suddenly around 1/2 throttle it picks up again. This threshold seems to vary slightly leading to severe jumping.
The issue seems more prevalent after the car is warmed up
the issue can come and go WITHOUT stopping the car/turning off ignition. It runs like crap for 5 minutes then suddenly is fine, even with CEL on.
I’ve also had a surging idle in the past, though it has been very minor recently and on its own not terribly concerning.
I’m wondering if the issue can be caused by a bad TPS? My reasoning is that it runs like crap in mid throttle range, then suddenly has power if I floor it. I don’t know if this is normal behavior for MAF issues. Would make sense if TPS is not reporting throttle opening.
What is a good way to test the TPS? I understand you have to check voltage, I don’t want to tear up my wiring harness. Any tricks how to do this?
I will do the FSM MAF procedures as well, but TPS is an easy replacement if we think that’s a likely culprit. Also, any good non-FSM tests to try first? I really don’t want to have to dig through the dash if it can be avoided.
I can't comment on if it could be caused by a faulty TPS.
That being said to test it I use needles or something long and thin to back probe the connector through the weatherpacking and then just test the voltage as you move the pedal. It should be a smooth sweep up to around 5v from whatever your specified FSM adjusted base voltage should be.
The needles slip between the weather pack and wire and when pulled out put the seal right back with no damage occurring.
TPS voltage seemed good. I ran through the FSM procedure and all the voltages on the harness were good-which indicates the MAF. The only thing is, that it had been intermittent.
I had another MAF sitting around from a parts car (that thing has been worth every penny) and so I swapped that in and went for a drive. No issues, no hesitation, just pure power and fun. I'm going to give it a few weeks of around-town trips, however, before I call it good for a cross-country road trip. Which is too bad, because it's my tenth anniversary and we're going for a weekend in the mountains and it would've been perfect. Ah, well.
Your symptoms sound very similar to my 85 when it was setting Code 34, which is the other MAF code. I eventually replaced the MAF after it shot craps altogether and was undrivable. No more MAF codes in the 20 years since.
Take the car on your anniversary trip. Carry the take-out MAF as a spare. If you have trouble, you can go back to the old MAF that usually clears up. But I think you'll be fine with the parts-car MAF.
Well we didn’t take the car but I’ve been driving it as much as I can after the swap and no issues so far (knock on wood)
