I'm not sure but, the logic I use, is that brake pads are cheaper and easier to get to. I only use OD @ 55mph or above and will use lower gears on mountain type or performance driving situations. Never for spot braking.
Back in the days when most cars had 4-wheel drum brakes, we worried a lot about "saving" the brakes when driving in hilly areas. On autos, that meant downshifting once in a while. It didn't seem to hurt.
Just remember to "blip" the throttle just as the gear changes, so the engine RPM matches the drivetrain.
I do on occassion....never seems to hurt :confused: Most of the time its from 4th to 3d but in town sometimes I go from 3rd to 2nd neither of them are under a heavy load, or excess RPM
i mostly do this during heavy performance touring at ROAD AMERICA or a sweet azz country road (plentifull in wisconsin). i usually rely on 2nd gear quite a bit and to get myself to higher speeds. i will downshift in bad weather to help slow myself down if conditions realy suck.
my mech "informed" me that the only gear that you need to pay attention to is 3rd. he said nine times out of ten that would be the first to go. and second gear in an auto trany will take a bigger beating than the 2nd in the manual trany. :steering:
Letting off the gas and using the tranny for braking will cause premature wear, guaranteed. Use your brakes, or buy a 6speed next time. As far as performance driving, make sure to accelerate first, THEN drop it down to 2nd, or else the transbraking could hurt the tranny. Also, use your head, dont drop it into 2nd on the highway doing 80mph! I think 65-70 is the most Ive felt comfortable doing it.
I downshift from 4th to 3rd on a down grade or otherwise to get some additional engine braking but tap the brake pedal first to unlock the TC thus reducing stress on the drive train, including the tranny.
I guess that each gear change produces some wear on the clutch packs.
Automatic 4 speed Transmission Shift Quadrant Positions. My owners manual says the following: 2-[second gear] This range is used when extra performancxe is required for hill climbing OR IT CAN BE USED TO PROVIDE ENGINE BRAKING TO SLOW THE CAR WHEN GOING DOWN MEDIUM GRADES. the shift lever may may be moved from "D" to "2" and vice versa under most driving conditions.
It also say the same as to "1" You may shift into "1" at any speed but the transmission will not lock into Low until the car speed is under 40 mph.
If I leave mine in D then it upshifts too fast. Once I was at 25mph doing barley idle in 3rd gear. My transmission upshift too much so I do it m self, With a shift kit, makes you enjoy your corvette much much better :yesnod:
I always do....... my trannies last over 100k .........I drive it like a manual trans I shift up and down manually all the time unless I have my cup in my right hand ........then I usually "pre-shift" ......... :lol:
:bs :bs :bs I did it at 70 ONE TIME and she did it. I thought it was coming apart. I did not mean to.
:eek: :eek: :eek: I also did this by accident but more around 50ish. The trans didn't downshift til 40 mph and when it did I almost went for an unforgiving ride! I probably woulda poopied my pants if it downshifted @ 50+ mph! :lol:
I do shift it manually, well at least I did. These single piston calipers SUCK!!Since engine braking is much better with the 3.54 than the 2.59, I doubt I'll need to manual downshift much anymore. ;)
