Pulling trouble codes...
Old Jan 4, 2003 | 09:40 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Pulling trouble codes...
Is there any way to make a corvette show the code number like the Caddies do on the a/c temp display or something?
Old Jan 4, 2003 | 11:22 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Pulling trouble codes... (CarAteMyMoney)
It can be done by grounding specific pins on the DLC or with a scanner. What year do you have?
Old Jan 4, 2003 | 11:33 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Pulling trouble codes... (lou sylvestri)
I think he has an '86. Believe he's out of luck on codes w/o using a scan tool (?)
Old Jan 4, 2003 | 11:37 PM
Light84vette's Avatar
Light84vette
Default Re: Pulling trouble codes... (Lone Ranger)
Could this be done with an 84?? :confused:
Old Jan 5, 2003 | 02:51 AM
CarAteMyMoney
Default Re: Pulling trouble codes... (Light84vette)
reason I asked is some sneaky individual unplugged the SES light so i couldn't do it with the ALDL connector. i ended up putting the socket from the door ajar lamp there so i could pull the trouble codes with a paper clip :cheers:
Old Jan 5, 2003 | 02:54 AM
Light84vette
I dont really get this pulling code thing. DO you put in a computer dyagnostic in the port under the dash of the drivers side for the codes? OR does it display on the LCD? :confused:
Old Jan 5, 2003 | 03:17 AM
CarAteMyMoney
My friend's old caddy used to display em on the A/C LCD but apparently vettes dont do that. All you have to do is touch each end of a paper clip to the correct terminals on the connector (look in a book) and count the flashes... There's an article about it that makes it pretty easy on c4vettes.com
Old Jan 5, 2003 | 03:34 AM
superlund's Avatar
superlund
Check this site out, for pulling codes from the PCM...
http://www.c4vettes.com/ecm.htm
IMHO the best thing a guy can do is buy a cable from AKM cables for about $80 & then use the free trial version of Datamaster to pull codes, you will get much better Info on what the sensors Etc are reading...
http://www.mindspring.com/~amattei/akmelect.htm http://www.ttspowersystems.com/dm_dload.htm
And BTW the electronic AC controls on the late C4's also have diagnostic capability's for the AC control system, you can actually retrive codes from it also, just like the PCM, just something to keep in mind...
:seeya
Old Jan 5, 2003 | 11:57 AM
CarAteMyMoney
Default Re: Pulling trouble codes... (superlund)
I normally use a Monitor 2000 but I'm waiting on the right cartridge for it
To Pulling trouble codes...
