I-beams vs. H-beams
Old Jan 5, 2003 | 08:06 PM
kawboy5792's Avatar
kawboy5792
Default I-beams vs. H-beams
i know H-beams are stronger...but how much can I's take?
Old Jan 5, 2003 | 08:24 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: I-beams vs. H-beams (kawboy5792)
You're going to have to give more info. You haven't defined the problem yet.
And an I-beam section isn't necessarily stronger than an H-beam, it all depends on sectional area, etc.
Old Jan 5, 2003 | 10:06 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: I-beams vs. H-beams (Matt Black)
If you are going to use a aftermarket rod, There a several top quality I beam and H beam rods out there. I am using a I beam rod.
Old Jan 5, 2003 | 10:46 PM
kawboy5792's Avatar
kawboy5792
The problem is im going to do a stroker and want to know whether the H-beam is necessary...thinking of manley or eagle rods. :yesnod:
To I-beams vs. H-beams
