Injectors
Old Aug 19, 2022 | 12:20 AM
Jez28's Avatar
Jez28
6th Gear
Default Injectors
Hi all,
Hope you can help me with some advice.
89 TPI
The previous owner installed high lift rockers and a 56mm throttle body, I have noticed it misfires when it warms up, not a regular miss just the odd pop at reflowed rpm”s and idle. My question is should it have higher flow injectors for these modifications?
Could this be the cause of the lumpy running?
Old Aug 19, 2022 | 08:45 AM
THE 383 admiral's Avatar
THE 383 admiral
Originally Posted by Jez28
Hi all,
89 TPI
Welcome 89 TPI
The PO. these are the "only" mods?
did they install 1.52 or 1.6 aftermarket rockers. Minimal lift gain approx up to .030
Aftermarket TBs are 52mm or 58mm no real difference.
Need a part number for the injector. ID the lbs/hr
If the PROM was not updated to match unknown INJ. Pulse width, lbs/ hr & related. This will create a AFR problem.
The rest of the components. Wires, FP, fuel pressure, plugs cap, rotor all in good working condition.?
