1993 lt1 ecm
Old Aug 23, 2022 | 08:00 PM
LiteswitchC4's Avatar
LiteswitchC4
1st Gear
Default 1993 lt1 ecm
ECM in my 93 has bit the dust, remanufacturers say they cant fix it. If i buy a functioning 92 or 93 ECM pulled from another car would I be able to just drop it in and have my car running again? also any hints on where to locate the ECM i need would be greatly appreciated.
thanks for any advice.
Old Aug 23, 2022 | 08:51 PM
s carter's Avatar
s carter
Give mirrock Corvette in Saltsburg PA they might have one if anybody would
Old Aug 24, 2022 | 06:59 AM
pedricd's Avatar
pedricd
What remanufacturers? I’m assuming SIA?
You need your PROM from the old ECM.
92-93 ECMs are the same as several other LT1 cars of the era (Camaros etc). So while not a huge supply there are more out there than you might think. You just need a matching ECM from any of those models, swap in your PROM and you should be gtg.
Old Aug 25, 2022 | 11:36 AM
Kevova's Avatar
Kevova
Unfortunately 93 was not a big production year for lt1s 93 z28, trans am, and formulas are candidates. There are a fair amount of people parting out f bodies. Pick n pulls.
Old Aug 27, 2022 | 06:59 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
They are getting harder to find. Part number 16159278, ebay may be the best bet.
Old Sep 1, 2022 | 07:32 PM
barchetta1's Avatar
barchetta1
Does the 93 have the detonation detect chip in the bottom? If it does you need that back. I thought your car could use any lt1 besides 96? I even think a 96 would work if you just programmed out the 3rd O2 sensor. I know the other way works.. (95 in a 96).
Id be curious as to what could fail that would make your ecm unrepairable.. Id ask for it back. How did it go bad and how did you determine it was bad. that is not an easy thing to do (diagnose right down to the ecm without swapping one in).
If you can get your hands on a programmer, Id connect the old ecm and see if you can pull your existing programming and then send it to the new one. IF it is "broke" it doesnt mean it wont have a conversation with a programmer.
Old Sep 1, 2022 | 07:49 PM
pedricd's Avatar
pedricd
Right. I asked the same question about WHO said it was toast. I bet it wasn’t SIA!???
You cannot just swap computers with a later gen. You might be able to adapt a later ECM but it requires messing with the harness a bunch AFAIK. One old thread talking about..I think there is another where someone swapped the whole harness…if you have an auto that further complicates…
https://www.corvetteforum.com/forums...equential.html
Old Sep 1, 2022 | 08:00 PM
barchetta1's Avatar
barchetta1
ok I stand corrected I guess. I know it is common to swap back to a non obdii.. but come to think of it, you might have to swap a couple of wires. look for one cheap and research what needs to be done then buy it if it is no big deal. Or spend the money and just get the right one.. but I wonder about your 'broke' ecm..
You didnt say anything about programming.. but if you did do that it is common to mess up the boot loader if your programmer hangs.. in which case,all you need to do is solder in some sockets, program two new chips with a eprom burner and you are back in business. I did a complete write up on that on here years ago. No Ecm gets the best of me.
Old Sep 1, 2022 | 08:03 PM
pedricd's Avatar
pedricd
I’m not the op, but maybe you weren’t directing that at me? I wish the OP would pop back on here so we could help but seems to be MIA.
Old Sep 1, 2022 | 08:13 PM
barchetta1's Avatar
barchetta1
Sorry.. I was directing some of that to you and some to the OP. Sorry about that.
Something about the ECM being bad smells fishy to me.
Old Feb 11, 2023 | 02:58 PM
Tunedport90's Avatar
Tunedport90
Few on eBay right now
To 1993 lt1 ecm
