Throttle Cable Adjustment?
Old Aug 27, 2022 | 12:36 PM
Cornhusker's Avatar
Cornhusker
Default Throttle Cable Adjustment?
I read at the end of an IAC/TPS adjustment that one should next adjust the throttle cable, can that be done & if so how?
I searched the net but found nothing. My vette is an 89 with a manual trans. Thanks
Old Aug 28, 2022 | 08:52 AM
FostersPerformance's Avatar
FostersPerformance
Didn't know they can be adjusted....make sure at idle the throttle body is fully closed and on the stop. Then make sure (with someone in the car) you have wide open throttle with the gas pedal fully depressed.
