84 High Oil Pressure
Old Sep 3, 2022 | 01:26 PM
elkprairie's Avatar
elkprairie
Default 84 High Oil Pressure
I had a shop convert my stock 350 to a 383. Ever since, the oil pressure starts out at 80 psig and after warming up is around 50 - 60 psig at idle (700 rpm). Cruising at 1800 to 2000 rpm, the pressure goes back up to 80 psig. I thought my pressure sender was bad so I replaced it with a MasterPro part # 2-8128, It reads 80 (full scale) when I turn the key but before starting the engine. The old sender reads 2 - 5 psig when I turn the key but before starting. This is the second MasterPro sender I've tried and they both do the same thing. When I put the old sender back in, the readings are as before so I don't think its a bad connection unless the wiring is different for the new senders.
Ever since the conversion, the engine burns about a quart of oil per tank of gas. I've asked several shops about it and I usually get the reply that some rebuilds just run loose. I am past the ability to remove the engine again to have it looked at so I just keep adding oil (15w-40 was recommended by the rebuild ship). As we said in my younger days, "Fill up the oil and check the gas."
My questions for the Forum are:
1. Is this higher pressure normal for a 383?
2. Do I have the correct replacement sender for a 1984?
Thank you for your replies.
Don
Old Sep 3, 2022 | 02:17 PM
84 4+3's Avatar
84 4+3
I would get a cheap pressure tester and check the pressure first. Full scale at key on is normal but it should zero.
Old Sep 3, 2022 | 05:22 PM
Phobos84's Avatar
Phobos84
When the shop built your 383 did they put in a high pressure pump? 80 psi isn't a bad thing, mine hits 70 psi sometimes. But the oil consumption is the part that would concern me. How many miles are on the new motor? Was it broken in properly? Also the 15w-40 isn't doing you any favors. After break in I would swap that out for 5w-30 and see what happens.
Old Sep 3, 2022 | 09:21 PM
elkprairie's Avatar
elkprairie
When I tested out the new oil pressure sender, all I did was plug it into the harness. After doing some research I found the sender is grounded through the threaded end. When I connected the threaded end to ground, the pressure read 0 when I turned the key. After screwing the sender into the fitting connected to the manifold, I started the engine and the oil pressure was around 70. Problem 2 solved.
A high pressure pump was installed by the shop so I guess pressure around 70 is ok. Problem 1 answered. I use 15w-40 because that was recommended by the shop. There is probably about 1000 miles on the engine since the rebuild. Its been about 7 years since the rebuild. I got my private pilot's license soon after the rebuild and didn't have time for the Corvette. I followed whatever the shop recommended for the break-in.
Thank you for your responses.
Old Sep 4, 2022 | 08:22 AM
ex-x-fire's Avatar
ex-x-fire
They are recommending 15w40 because is a diesel oil with more additives for friction protection. You can use a 10w30 diesel oil. As far as the oil consumption, I'd look into oil being sucked up at the intake ports in the valley. You can try thicker intake gaskets.
Old Sep 4, 2022 | 09:20 AM
Incorvettei's Avatar
Incorvettei
80 PSI is maximum reading on the gauge. I would check the wire going to it.
Old Sep 4, 2022 | 09:27 AM
Phobos84's Avatar
Phobos84
A couple other things to consider here. When they built the motor what kind of rings were used? Did they use a plated steel top ring? I had a similar issue with mine. Some steel top rings have a long break in period. During this time you will see a lot of oil consumption. For a basic 383 build I doubt this is whats going on. Steel top rings are really needed for high compression or power adders. Otherwise ductile Iron works just fine.
2nd is this oil recommendation. I 100% agree with ex-x-fire in that the diesel oil has a slew of additives and really is some amazing technology as far as oil is concerned. But most shops recommend this kind of oil for break in for a lot of reasons. But at this point I would pour in a traditional 10w-30 or a 5w-30. Watch your oil pressure very closely and see what happens.
Old Sep 4, 2022 | 04:47 PM
84 4+3's Avatar
84 4+3
Depending, I would suspect the 15w-40 may be because the engine was built using a flat tappet cam... depending on the oil it may create issues. If it is a roller cam then I'd agree, 10w-30. Being it is 7 years old now, it very well could have a flat tappet in it... food for thought.
Old Sep 4, 2022 | 09:32 PM
elkprairie's Avatar
elkprairie
The cam installed was Lunati 60101LK - Lunati Voodoo.
Melling High-Volume Oil Pumps M-55HV was installed.
Old Sep 5, 2022 | 05:17 AM
84 4+3's Avatar
84 4+3
If you go to a lighter oil viscosity I would use a ZDDP additive. Unless you use somethijg like rotella in the 10w-30 type. That should be fine. I'd lean to the side of caution on it though.
Old Sep 5, 2022 | 09:48 AM
elkprairie's Avatar
elkprairie
Thank you for all the replies and advice. I've got a couple gallons of 15w-40 so I'll stick with that for now. It doesn't get driven at all in the winter so next spring I'll switch to a lighter weight Rotella and see what happens. I'm headed for the Eureka Springs Corvette Rally later this month so I'll see what the oil consumption is on long drives; will be taking a gallon of oil with me.
Old Sep 5, 2022 | 11:34 AM
Deepa's Avatar
Deepa
Be careful with HV oil pumps. They put a lot of strain on the distributor and drive gear as that’s how they’re driven.
What dizzy gear is on the car? Stock? Carbon fiber? Bronze? What’s the gear on the cam made of?
Old Sep 7, 2022 | 02:54 PM
elkprairie's Avatar
elkprairie
The dizzy gear is stock. I cannot find the material of construction of the cam gear.
Old Sep 7, 2022 | 07:14 PM
wilcar's Avatar
wilcar
That 60101 cam is a cast iron flat tappet camshaft and should have a cast iron gear too.
To 84 High Oil Pressure
