Wiper blades
Old Sep 5, 2022 | 09:10 AM
NARDA1's Avatar
NARDA1
2022 C4 of the Year Finalist - Unmodified
Default Wiper blades
I replaced my wiper blades the other day and now they catch on the underside of the hood and get stuck. I work at O'Reilly's so I was able to try several sets of blades and all of them had the same issue. Is there a special brand of wiper you have found that works?
Old Sep 5, 2022 | 09:33 AM
CorvetteRules's Avatar
CorvetteRules
I use RainX and have used them in 91 I had and now in the 95, They park perfectly.
Old Sep 5, 2022 | 09:44 AM
NARDA1's Avatar
NARDA1
Those are one of the brands I tried and they sit to high off the windshield causing them to catch on the underside of the hood.
I'm going to try adjusting the hood up a little bit to see if the blades will clear. I just don't want to go too far because then the hood and fenders would be out of alignment with each other.
Old Sep 5, 2022 | 10:54 AM
WVZR-1's Avatar
WVZR-1
Trico does blades that work but you didn't mention year so.................
I can't/won't pass on part numbers. Trico 'Exact Fit' will do it.
GM/ACD also has blades that work but again 'year' matters.
** It seems that Trico now might suggest a 19" blade but if you measure I'm sure you'll find they are actually 20". I have a friend who would put a 19" on the drivers probably and a 20" stock length on the right.
Old Sep 5, 2022 | 08:28 PM
NARDA1's Avatar
NARDA1
it's a '94.
Old Sep 5, 2022 | 08:32 PM
Whaleman's Avatar
Whaleman
Rock auto has a closeout of Trico's at $1.24 a set. Dan
Old Sep 5, 2022 | 08:45 PM
WVZR-1's Avatar
WVZR-1
You're suggesting a R/A purchase for an O'Reilly Auto Parts employee? Amazing!!
Old Sep 5, 2022 | 08:58 PM
Whaleman's Avatar
Whaleman
Originally Posted by wvzr-1
you're suggesting a r/a purchase for an o'reilly auto parts employee? Amazing!!
oops!
To Wiper blades
