Can the knock sensor be fooled by other noises than detonation?For example would it respond to knocking from the dual mass fly wheel an ZF6 speed?
The knock sensor is a piezoelectric device that is tuned to detect certain frequencies. It is selected to be at a frequency that is normally associated with spark knock. However, there can be cases where other "noise" can be generated that will fool the knock sensor into thinking it is knock.
I don't think anyone can give you a definite answer on your question.
Since spark knock usually happens under heavy engine load, I would think if the knock sensor detects "knock" when the engine is not under load, then that knock would be suspect as being false.
