1986 codes
Old Sep 7, 2022 | 06:51 PM
Chm86's Avatar
Chm86
Default 1986 codes
I tried shorting pins A and B like you at supposed to check for codes. No codes or lights came up but the cooling fan kicked on. Any thoughts?
Old Sep 7, 2022 | 07:53 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Without shorting anything, just key on engine off, does the check engine light come on at all? Possibly bulb is burnt out or previous owner removed. With A and B shorted key on engine off, you should get at the minimal check engine light 1 flash followed by 2 flash, repeat... The fan coming on may be a good sign that it's in diagnostic mode.
Old Sep 7, 2022 | 08:22 PM
Chm86's Avatar
Chm86
So not certain if I am doing it correctly. With just the key partially on I get nothing. I have to turn it partially on to where you would turn over a little more and engine cranks. I might be turning it on too far but with the key just partially on it get nothing at all no lights or anything.
Old Sep 7, 2022 | 08:39 PM
s carter's Avatar
s carter
Just turn to run if it cranks a bit No Point No Fowl just let go of key, is the Service Engine/Check Engine light on? Yes or No
as mentioned with A/B jumped a code 12 should flash followed by trouble code if no code it will go with a code 12 after a pause
https://images.app.goo.gl/i8KEYBV7zyVGT8ts5
Old Sep 7, 2022 | 08:50 PM
Chm86's Avatar
Chm86
Short it out and turn it to on but no turn over. No check engine light comes in at all and the fan cones on. I turn it on normally with no short and still no check engine light. Never noticed it but doesn’t the check engine light typically comes on just as a check then go out when you start it? Tomorrow I probably need to heck to see if the previous owner removed the bulb.
Old Sep 7, 2022 | 08:58 PM
s carter's Avatar
s carter
With No jumping normal car key in run Not Running Check Engine light should be ON
So if you have No light pull the DIC check the bulb and circuit. Hopefully you find a dead bulb because after that we enter a world of ECM
Old Sep 7, 2022 | 09:17 PM
Chm86's Avatar
Chm86
Thanks. I will check it tomorrow. I have a spare rebuilt cardone ecm sitting in a box. I have not changed it out yet as I am a little hesitant as on the details of it it said something about possibly needing additional relearns on it and I have no clue what that entails.
Old Sep 7, 2022 | 09:27 PM
s carter's Avatar
s carter
Relax if you pull the ECM for swap just open the little hatch Carefully Release the Lock Tabs push outward at same time tabs should push up prom out of mount, remove the Prom (blue plastic bar) Carefully install into other reseat the lock tabs.
also check your fuses always start with easy and simple
To 1986 codes
