1) at the throttle linkage there are three cable: throttle cable, 2 TV cable and...3?
Yesterday I noticed that the gas pedal has 2 kind of travel. the main travel is for to open the throttle via throttle cable(C to D) an then there is a travel ... where the surface of the pedal can rotate up to the gas pedal stick (from A to B .- spring loaded travel-).
