Pulling codes on a 94 with out scanner tool
Old Jan 7, 2003 | 12:40 PM
jimijoe's Avatar
jimijoe
Default Pulling codes on a 94 with out scanner tool
Is there a method to pull the error codes from a 94 PCM with out having a scan tool.
There is an method on line at.. http://www.c4vettes.com/ecm.htm but this method is specific for a ECM (OBD I) setup (pre 94). This web page does says "For 1994 and later models, you will need to recover the codes using a special procedure involving the speedometer and the odometer as explained in the service manual or use a special diagnostic device known as a scan tool" I have the factory service manual (ST-364-94 volume 1&2) but can not find a method to pull the code. I miss driving my baby..Please help.
Old Jan 24, 2003 | 07:39 PM
C4TOMCAT's Avatar
C4TOMCAT
Default Re: Pulling codes on a 94 with out scanner tool (jimijoe)
sent email instruction pics
Old Jan 25, 2003 | 07:17 AM
84FromHell's Avatar
84FromHell
Default Re: Pulling codes on a 94 with out scanner tool (C4TOMCAT)
can you send me those too? Thanks!
Old Jan 29, 2003 | 07:31 AM
C4TOMCAT's Avatar
C4TOMCAT
Default Re: Pulling codes on a 94 with out scanner tool (84FromHell)
sent them this morning, sorry for the delay as I have not been online lately
Old Feb 2, 2003 | 11:45 PM
Brett612's Avatar
Brett612
could someone please send me those also, thanks alot!
Old Feb 5, 2003 | 12:47 PM
Glasman66's Avatar
Glasman66
Default Re: Pulling codes on a 94 with out scanner tool (Brett612)
me too please.
Old Feb 6, 2003 | 04:29 PM
Bob Mosaic's Avatar
Bob Mosaic
Default Re: Pulling codes on a 94 with out scanner tool (Glasman66)
if it isn't a burden, can I get hooked up with those as well?
Cheers,
Robert
ZambeziPT@aol.com
Old Feb 7, 2003 | 12:00 AM
kittmaster's Avatar
kittmaster
you should just post it as a tech tip that would simplify things for all with this issue
kitt
Old Feb 7, 2003 | 01:46 AM
jimijoe's Avatar
jimijoe
Default Re: Pulling codes on a 94 with out scanner tool (kittmaster)
I found the info on how to pull the codes with out a scanner on this web page ... http://www.c4vettes.com/codes.htm
I'm not sure who maintains this web page, maybe someone on this forum, but it has been instramental to me in keeping my C4 running. Thanks.
I think this info would be good to add to the tech tool tips but I am not sure how to add them. :party:
To Pulling codes on a 94 with out scanner tool
