Oil temperature sensor
Old Sep 17, 2022 | 03:16 PM
FRED0337's Avatar
FRED0337
1st Gear
Default Oil temperature sensor
1995 c4 oil temperature gauge goes directly to 320 degrees even when the car is cold..I have change the oil temperature sensor 3 times but still does the same thing when I start it up. Any suggestion would help..thanks
Old Sep 17, 2022 | 03:58 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
With the connector disconnected, does it still register 320*F? One of the wires is probably shorted to ground. Check if any of the wires are touching the exhaust and burned through.
