built simple flow bench to test ported heads, intake manifold
this is for a 1984 crossfire with ported intake manifold
low-cost simple flow bench. heads are summit/dart 165ss. I wanted to know if porting job did anything, it did. just comparing the manometer reading before and after porting. picture shows the lip left after valve job was done. made some covers to protect valve job during porting, there crude but they work. I bowl blended the lip and skinnied up the valve guides and removed casting imperfections. haven't de-shrouded the valves yet. need get some old valves for de-shrouding and make a cover to protect the head surface. Even the best can lose control of grinder and I'm a beginner, although I fabricated metal for over 40 years that included finishing with die grinders, so I'm very familiar with die grinders. maybe de-shrouding will give low lift gains.
after I take the intake and exhaust manifold off car, will then test them on the head. test those diffusers for sure.
this is fun stuff
The following 3 users liked this post by mike1111:
thanks . did a lot of reading and watching videos. david vizard books and so on. Its actually fun to me. It was nice to see gains for sure. It was just a bowl blend. the exhaust really needed it. very curious to see what ported intake manifold does
Pro Mechanic
In for learning. LOVE IT!!
Received 3,043 Likes
St. Jude Donor '05
Boy are you in for an education!! lol
Heres some decent info for the DIY person
Youll find deshrouding isnt always needed....lots to learn youll dig it.
http://www.flowperformance.com/system.html
PTS Flowbench Forum - Index page (flowbenchtech.com)
St. Jude Donor '05
Ah, PTS thats the one I was looking for,been yrs since Ive been on there. my mistake!
Shame one of the best areas for gains is a pain to get to and cant see it. The all important short turn
Have a similar mentality such as yourself..not about a max web hero flow# its about quality of flow, where it starts and gives up
Ea application is different. The "hogging out" look how big I got it mindset is decades old thinking.
Bet you know what can look impressive on a bench doesnt always work good once the engine is in the car.
Keep us posted always love reading about others projects.
dart heads with crossfire manifold
did a basic bowl blend on dart 165ss heads. modified crossfire intake manifold. welded on top of ports and welded round rod to runner entrance. blended the ridge left by valve job on heads. the exhaust ridge is pretty big. intake has a ridge mostly on left side if looking at these photos. exhaust got bigger gains.
intake manifold has more finish work to do. But it was good enough to test. cleanup work isn't going to make it flow better, it will just look better. Did flow each intake port and there all about the same flow. not sure if i'm going to block balance ports. could slot the top and drive in a piece of aluminum, then weld the top.
connected to dart heads the intake head combo flows 196 cfm at .425. At .500 its at least 200, but I'm not sure about that. using stock head to compare. Could be more. more testing to do.
exhaust tested about 180cfm at .500. its way more then the stock dart port 138cfm.
stock exhaust manifold flowed 125cfm @ .500. I cut the header tube at the collector where its pinched down and hammered the pipe out and grinded about an .125" out of the collector.it flowed about 155cfm after that. thats about max. the Id of the pipe is 1.325". should get headers.
Pro Mechanic
Looks good. I like the radiused runner mouths.
Pro Mechanic
Interesting. Cutting 'em back would increase the available space for air to get over the adjacent runners to get to the mouths of the "sucking" runner(s). I guess?
I should get myself a real welder... looks good.
Yeah. I had a friend TIG what was done on mine and he said it was one of the worst he's seen as far as dirty. I have a 160 amp MIG but I know that won't even touch the thing... I won't bother my friend with it again as for him to tell me it was bad, it was pretty bad.
there is a little different technique welding old manifolds
84 4+3 (11-18-2022)
thought I was done with manifold, but after testing today, going to fill holes. test with and without tape over hole. without tape cfm drops. put vacuum on adjacent runner with no tape it drops a little more. going to drill a slot in from the top ,then weld a piece of aluminum in from the top. after that
The following 2 users liked this post by mike1111:
84 4+3 (11-18-2022),
Fly skids up! (12-08-2022)
Pro Mechanic
I love how you sort of "wrapped" the runner pair mouths toward the TB's.
