Does that MAF mod really work?
Old Jan 7, 2003 | 07:20 PM
LayZ's Avatar
LayZ
Default Does that MAF mod really work?
Taking the screens out? TPIS will work yours up for a small charge but is it really worth doing? Will it improve anything?
Old Jan 7, 2003 | 07:40 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Does that MAF mod really work? (LayZ)
What year is your car?
In my 88, it would appear that the screens are important in helping ECM to adjust fuel. they work, I believe, in conjunction with TPS.
I have read about people gutting the screens, but have seen no real evidence that it is an improvement. Maybe some SOTP's comments, but no real evidence. IMHO!
I have tried most of the "free Mods" and the only one I can truly say made a real significant difference was removing the "frisbee" on my L98. I am also quilty of SOTP on this, but I do know Iam a little quicker out of the corners as engine revs up a little quicker.
Cutting lids, throttle bypass, really didn't add anything for me, again SOTP!
:cheers: Let the Flames begin :D :D
Jack :steering: [I love that Lil Guy]
Old Jan 7, 2003 | 08:41 PM
LayZ's Avatar
LayZ
Default Re: Does that MAF mod really work? (jackdaroofer)
86, auto, 3:07 gears. I did the cut lid and K&N and it really made a diffrence. I didn't think the L98 had the frisbee problem i thought it was 91's and up.
Old Jan 7, 2003 | 08:49 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Frisbee is on l98's, maybe 88 and up. Mine is an 88
Old Jan 7, 2003 | 09:20 PM
vader86's Avatar
vader86
You should just remove the screens in front of and behind the sensor element. I would not mess with the fins inside it. Just opening that up will give you a couple hp. Dont pay someone to do it or buy a modified part. Save your money for real mods.
Old Jan 7, 2003 | 09:54 PM
LayZ's Avatar
LayZ
Default Re: Does that MAF mod really work? (vader86)
Ok why not the fins just curious, Could i use a dremel to cut the screens out and do i need to make them smooth or is there a section on this in the tech tips?
Old Jan 8, 2003 | 03:45 AM
merrick's Avatar
merrick
Removing the screens gains a substantial amount of CFM's (L98 only). Removing the fins too is not worth the effort on a lightly modded engine. Besides the fins have a function.
Old Jan 8, 2003 | 07:26 AM
Vic'89's Avatar
Vic'89
Default Re: Does that MAF mod really work? (merrick)
On an L98, this mod works.
I have removed the screens and fins on my MAF sensor.
Vic
Old Jan 8, 2003 | 07:27 AM
hngacurv's Avatar
hngacurv
Decent mod for the L98 to increase CFMs. Worth only a couple of HP though without a heavily modded motor.
Old Jan 8, 2003 | 11:03 AM
jtjerry's Avatar
jtjerry
Default Re: Does that MAF mod really work? (castivers)
On my ‘88 that mod work.
First I done screens remove and second cut that fins.
After first I saw improvement, after second (fins) not.
In my opinion that free mods (cut air lid, KN filter, TB bypass and MAF screens remov.) works and I really feel that work on my car.
Jerry, Poland
Old Jan 8, 2003 | 12:34 PM
vetracer's Avatar
vetracer
:iagree:
You can remove the screens with a utility knife. If you live in a warm climate, I wouldn't mess with the fins. they are there to help dissipate heat from the MAF. According to TPIS, GM had some MAF failures during hot weather testing and added the fins.
[Modified by vetracer, 5:36 PM 1/8/2003]
Old Jan 8, 2003 | 02:53 PM
LayZ's Avatar
LayZ
Default Re: Does that MAF mod really work? (vetracer)
OK glad i picked up a second MAF from a 88 just in case. Now is there a trick to this or can i just cut the screens out completly? do i have to be careful of something or cut away?
Old Jan 8, 2003 | 02:59 PM
vader86's Avatar
vader86
You dont need to cut the fins because theres a chance of you hitting the sensor element with a knife or something, and if you do that you might be buying a new sensor.
You can cut out the screens with a knife or whatever.
Old Jan 9, 2003 | 12:22 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
it all depends on how much power you are after :cheers:
Old Jan 9, 2003 | 12:28 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Does that MAF mod really work? (CORKVETTE1)
As far as the fins go, someone hit the nail on the head...the fins are the heatsink for the powersupply for the MAF. If the power supply overheats, or even changes temperature significantly, it will screw up your MAF signal to the computer.
The screens do allow more air to pass through, but here's the trick....you're allowing more air to pass through, but at the same velocity as the original airflow...what this means is that the engine thinks you're getting less air than you really are. This is a bad thing. I did it before I knew what I was doing, and lost power on the dyno. This is because the engine was now running what it thought to be the correct A/F ratio, when it was really too lean. If I were you, I'd leave it alone.
To Does that MAF mod really work?
