Hard top
Old Sep 27, 2022 | 06:08 PM
Haffly12's Avatar
Haffly12
2nd Gear
Default Hard top
Got a question for you all. Winter is coming and I would like to put my hard top on instead of my glass top. Do I need to change any hardware for this because my hard top is noy lining up like my glass top does.
Old Sep 27, 2022 | 06:32 PM
s carter's Avatar
s carter
Don't adjust car to top, adjust top to car then you can swap at will. As long as you have the same style hardware you should be able to get both tops to fit, in the odd occasion you may to need to adjust car a little to find a mutual fit.
Old Sep 28, 2022 | 07:55 AM
Haffly12's Avatar
Haffly12
2nd Gear
What hardware do I need
Old Sep 28, 2022 | 08:24 AM
s carter's Avatar
s carter
does your hard top have any hardware on it, it should look just like the clear top if it doesn't what is missing is what you need. It is important that you have the same style roofs there have been several Design changes over the years, otherwise you would be changing car hardware and you don't want to open that can of Headaches because you would be changing car to match the style of roof your going to use.
https://corvetteparts.com/search?q=roof
Old Sep 28, 2022 | 09:12 AM
GRIS's Avatar
GRIS
Be sure the car is on the level when you put top on.
To Hard top
