Changing my Opti, help!
Old Jan 8, 2003 | 12:00 AM
goalie31's Avatar
goalie31
Default Changing my Opti, help!
I'm changing the opti, water pump, plugs and wires this weekend on my 94 LT1. Any helpful suggestions or tips would be apprecriated.
Bill Ankerholtz
Old Jan 8, 2003 | 12:04 AM
don hall's Avatar
don hall
Default Re: Changing my Opti, help! (goalie31)
You might try the TECH TIP Forum.....there are step-by-step instructions available.
Old Jan 8, 2003 | 12:11 AM
goalie31's Avatar
goalie31
Default Re: Changing my Opti, help! (Oldman)
Thanks, but where in the heck is the tech tip section? I thought this was the area. Please point me in the right direction.
Old Jan 8, 2003 | 12:17 AM
don hall's Avatar
don hall
Click on TOOLS at the top of the page, then scroll to C4 TIPS..............
Old Jan 8, 2003 | 03:00 AM
JayH's Avatar
JayH
have a good set of internal and external torx drivers on hand. I believe the rotor is a t5 and the cap retaining screws are an e6, but it the number might be reversed. I had to trim the handle on the t driver to get it to fit and shave some of the bevel from the e driver to get it far enough in the cap holes.
The biggest PITA about the job IMO is getting all the coolant when it comes splashing out the various hoses on the WP.
Good luck and don't touch the sensor!
Jay
Old Jan 8, 2003 | 05:58 PM
69mako's Avatar
69mako
Default Re: Changing my Opti, help! (JayH)
Have fun with the wires....what a major pain...not too bad when the water pump is off and out of the way...GOOD LUCK Opie :thumbs:
Old Jan 8, 2003 | 06:19 PM
goalie31's Avatar
goalie31
Default Re: Changing my Opti, help! (69mako)
Yeah, I did the wires about 2 years ago. I wish I would have pulled the opti and changed it. How hard is it to get the balancer off?
Bill
Old Jan 8, 2003 | 10:06 PM
DRAGRCR1005's Avatar
DRAGRCR1005
[QUOTE]Yeah, I did the wires about 2 years ago. I wish I would have pulled the opti and changed it. How hard is it to get the balancer off?
Bill[/QUOTE
THE BALANCER IS EASILY REMOVED BY TAKING THE THREE BOLTS OUT THAT CONNECT IT TO THE HUB ON THE CRANK. THE OPTI IS CLOSE TO IT BUT IT CLEARS. THIS WILL SAVE YOU TIME VERSES PULLING THE HOLE THING WITH A BALANCER PULLER. THE HOLE JOB IS PRETTY STRAIGHT FORWARD. AFTER REMOVING THE WATER PUMP YOU WILL HAVE A CLEAR SHOT TO ALL THE BOLTS CONNECTING THE OPTI TO THE BLOCK. THE TIMING IS NOT ADJUSTABLE AND THE SHAFT IS INDEXED SO IT CAN ONLY GO IN ONE WAY. I WOULD REPLACE THE WATER PUMP INLESS IS HAS VERY LOW MILES. MY CAR HAD 88K AND THE ORIGINAL PUMP WAS FINE AND NOT LEAKING BUT I REPLACED IT ANYWAY. MY LUCK IT WOULD START LEAKING THE NEXT WEEK AND RUIN MY VERY EXPENSIVE OPTI.
Old Jan 8, 2003 | 11:19 PM
Admiral Fairway's Avatar
Admiral Fairway
Go to the Northeast section and ask for Rex Ruby, he just did his this summer on his '93.
To Changing my Opti, help!
