Clunk when I roll it backward by hand.
I needed a foot or 2 to get my hood to clear in the garage, as I pushed it backward by hand it had a recurring clunk, I am guessing from the rear end area. It does not do it going forward. No sensation of clunking under power in reverse. I should also mention the last owner either had a lot of rear camber in it or the fasteners slipped, maybe as much as 2°. This camber will be removed soon.
Any ideas appreciated.
Donny
Thanks all for the help
Vader86, s carter, Jud Chapin, incorvettei,
87 coupe (hatchback) 82k. The ujoints did fix the problem. I think they were original, one side of the body had "SPICER" and "94 63" but the 9 and the 3 were odd looking. On the backside appeared to be "F1". When I looked closely at them I was surprised they had little to no damage except some signs of heat and one small area of pitting. They were all very smooth with no feeling of roughness. The odd thing was they were all completely limp, wobbly with no friction at all but I could not find any play. All of the caps that were held on by clips fell off when removed and the 2 rear yoke strap caps fell to the ground when pulled from the diff yoke. @s carter, all 4 wheel bearings needed replacing, thanks. Admittedly, the driveshaft had been out before as the pinch weld had been moved.
Replacements, (thanks Vader86)
4 Dana spicer Non-grease heavy duty 53615X for aluminum half shafts
2 Dana spicer Non-grease heavy duty 53613X for aluminum driveshaft
