ECM Swap/back up
Old Oct 13, 2022 | 12:50 PM
FirstTimeVetteNJ's Avatar
FirstTimeVetteNJ
Default ECM Swap/back up
I semi know the answer but I wanted to confirm one thing, I am looking for a backup ECM to have for a 92 LT1. The current ECM I think needs to be fixed or maybe is just bad because its been "fixed" before. Anyway I found a good deal in a 1993 Camaro ECM, which I know will work, using my cars current PROM, but my question is things like the selective ride control would an ECM from a Camaro not allow things like that to work on the Corvette or is that all controlled in a different way and the swap would work.
Thank you for the help,
David
Old Oct 13, 2022 | 02:12 PM
THE 383 admiral's Avatar
THE 383 admiral
David
F- body has a $DA3 PROM
Y- body has a $DA2 PROM
i looked at the tables. I did not see any such option to conctrol. Indicating. Not controlled via ECM.
Old Oct 13, 2022 | 04:47 PM
FirstTimeVetteNJ
Thank you that is very helpful. I want to make sure that whatever direction I go its a somewhat an educated one. This might be a far out there question, but you do happen to know where on the ECM board the ground signal is sent from the ECM for these two the relays, I have two issues currently, the fans don't run when they should be commanded to run from the ECM (via A/B grounding, hitting the turn on coolant temp, or turning on the A/C) and the A/C clutch relay doesn't engage after the 20 second engagement window. Most of my issues seem to be centered around the RED block connector on the ECM and I wanted to see if looking at the actual ECM board had any clues.
Old Oct 27, 2022 | 08:32 PM
FirstTimeVetteNJ
Closing the loop here, a different ECM solved the issues.
To ECM Swap/back up
